Author Topic: Quick wheel bearing question...  (Read 2622 times)
Offline DaytonGuy
« on: November 20, 2010, 06:53:28 AM »
Ok....so I removed the old ones, painted my hubs, and installed new bearings.  Now I've decided i want to powder coat the hubs.  If I remove the new bearings can I reinstall them when finished.  Does tapping them out damage them in any way?
Thanks
bollingball
Re: Quick wheel bearing question...
« Reply #1 on: November 20, 2010, 06:55:22 AM »
No as long as you don't tap on the inner race.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: November 20, 2010, 06:56:37 AM »
.... and it's nearly impossible to remove them without tapping on the inner races.
mystic_1
- John Augustus Shedd
bollingball
« Reply #3 on: November 20, 2010, 07:09:35 AM »
+1 get a new one ;)
Offline DaytonGuy
« Reply #4 on: November 20, 2010, 08:34:20 AM »
That's what I figured, but I thought I would ask.  At least there not too expensive...... ::)
Offline Kong
« Reply #5 on: November 20, 2010, 12:08:02 PM »
Don't be in such a hurry to think you'll destroy them taking them out.  Just get out your brass drift and start tapping around the edges and keep moving.  You may, in fact I'd go so far as to say you most likely will, find that you've done no damage to them at all.  They shouldn't have been very hard to get in, they shouldn't be very hard to get out.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: November 20, 2010, 12:19:31 PM »
But do you want to go to that trouble again to find out you did?
Offline haggeo
« Reply #7 on: November 21, 2010, 10:58:45 AM »
Thanks
a bearing remover will get them out. i have not damaged any races or bearings with this yet. a drift works too but you are always one slip away from a damaged race, especially if it's your first time.
« Last Edit: November 21, 2010, 11:00:38 AM by haggeo »
bollingball
« Reply #8 on: November 21, 2010, 11:44:40 AM »
That is a good looking tool. What brand name is it? How much? where to buy?
                                                 Thanks Ken
Offline haggeo
« Reply #9 on: November 21, 2010, 04:43:54 PM »
http://pitposse.com/whbereset.html
i think it was about $2 cheaper when i bought it in 2008 but it's been very much a frustration saver for me more than once since then.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #10 on: November 21, 2010, 05:40:24 PM »
Or build the tool described in this article (6"x1/2" bolt with slot cut in threaded end):
http://www.goldwingdocs.com/forum/viewtopic.php?f=11&t=69
I think it will destroy your bearing's inner race though.  But new bearings would be cheaper than the Pit Posse tool.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline camelman
  • Man... Myth... Legend
« Reply #11 on: November 21, 2010, 06:36:47 PM »
Whoa!!!  why do you think you need to remove them?  I just powdercoated some hubs with the bearings in place, and they came out just fine.  Powdercoating temps aren't high enough to damage the bearings.  Just make sure you won't dribble grease everywhere when the bearings heat up, and make sure you regrease them when done.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #12 on: November 22, 2010, 04:47:31 AM »
How are you gonna hang them without the grease running out?
Offline camelman
« Reply #13 on: November 22, 2010, 07:16:48 AM »
I laid them flat on a table and slid them into a glass furnace.  I can't remember what we placed underneath them to catch oil dribbles, but what little came out didn't touch the parts.  I think we got a little on some of the oven bricks, but a quick run to 800F burned off any residual oil.
Actually, if you are going to a powdercoating shop, then you'll probably need to remove them.
Camelman
Offline DaytonGuy
« Reply #14 on: November 22, 2010, 02:57:59 PM »
Thanks.  It's not the powder I'm worried about.  It's the chemical dip/strip process I don't want to put the bearings through.
