Author Topic: "Big Bore" oil ring job  (Read 1306 times)
Offline Hannibal Smith
  • 3rd Grade Dropout
« on: November 20, 2010, 09:37:03 AM »
Well, machining a wider oil ring groove in the pistons to convert the "Henry Abe" piston kits to a 3 piece oil ring is a snap.
Didn't want to mess up the pistons, so I took my time in the lathe, and cleaned the chuck-jaws between each piston......and they all turned out perfect! Whew!
I machine stuff everyday for a living, and I still get nervous, maybe that is why I have a reputation as a good machinist ;D
Anyway, I feel very confident with my new 3 piece rings. I purchased the made in Japan Riken ring sets, and they sure look quality to me. I am paranoid about counterfeit parts, and these have the Riken hologram and they came from BikeBandit, so I am sure these sets are legit.
« Last Edit: November 20, 2010, 09:44:42 AM by Hannibal Smith »
Follow my build "P38 Racer" in Project section
Offline fastbroshi
  • Puppet
Re: "Big Bore" oil ring job
« Reply #1 on: November 20, 2010, 10:01:55 AM »
Nice job there Hannibal
Just call me Timmaaaaay!!!
« Reply #2 on: November 20, 2010, 10:10:23 AM »
 I hate chucking a piston on the skirt..or chucking the ring area..
 I try to make a plate to fit the chuck, with a hole thru the middle then pull piston up againt it using  the wristpin.
 Make a rodend like eye to fit loose over the pin, then a threaded rod & washer to pull it up tight against the fixture.. if you follow.
 Are you cutting one side only of the groove? Dial-test indicator is a must on this job..
« Last Edit: November 20, 2010, 10:13:10 AM by 754 »
  • 3rd Grade Dropout
« Reply #3 on: November 20, 2010, 10:29:11 AM »
That sounds like a good safe method- I used brass shimstock (.003) and then indicated each piston with a back stop ( fixed rod through the spindle trick) then machined to .109" width only taking from the skirt side, I used a cutter at an angle that ensures you get a perfectly parallel back "wall" on the groove.
The pistons were all perfect to .0005 on top to oil-ring groove distance, so the stop made it a 20 minute job.
« Reply #4 on: November 20, 2010, 11:09:26 AM »
 In Sept I widened the grooves on a par of big-bore pistons.. they were for 5.800 bore... :o
Offline Big Jay
    • CBRzone
« Reply #5 on: November 21, 2010, 03:08:42 PM »
If you have aluminum jaws for the chuck, bore them for the piston size above the rings. Then take a face cut so them so it is dead square to the bore.
Put a top ring in the piston and put it in the chuck, up against the ring. It will now run dead nuts true when you turn it on.
« Reply #6 on: November 22, 2010, 11:32:48 AM »
OR, don't machine them and just do a search and you can find the Total Seal part number for 3 piece oil rings that fit our Henry Abe 900 pistons. I forgot where I put that info. May be in the TECH section.
  • 3rd Grade Dropout
« Reply #7 on: November 22, 2010, 11:37:05 AM »
These are the "605" HA pistons, anyway, what fun is that? :D
« Reply #8 on: November 22, 2010, 11:41:44 AM »
Yeah, I know what you mean. Wish I had your talent and equipment!
My pistons are the same as your's.
Here's the link
http://forums.sohc4.net/index.php?topic=48656.0
« Reply #9 on: November 25, 2010, 08:25:18 AM »
 Jay, I got to ask if you are using a small lathe to do this? and if you ever have runout on the bottom of the ring groove.
 The reason I ask is; if there is runout, you can easily adjust it, if it is pulled up against the chuck with a drawbolt. ( a truing cut, plus a small inset 10-20-thou bigger than piston, will aid setup )
 The other problem I have with your method is the lathe I usually use (16in) has too much startup torque, For the amount I would feel comfortable with clamping the chuck on an aluminum piston, it would probably fly out, upon restart.
 Just a warning, I would not even sweat it on my smaller SouthBend, I can slack the belt tension and soft start it if necessary..
