Author Topic: K8 effng rear brake lever return spring!!!! help please!  (Read 1664 times)
Offline hevykevy420
« on: March 15, 2006, 12:48:33 PM »
OK, I"m a nubee but i searched forever and couldn't find this anywhere so I hope someone could kindly help me out. :) Or, point me to the post where this question was answered!
I'm trying to reassemble the rear foot brake lever and the spring that returns the foot lever to the "off" position.  I can't figure out how to assemble the GD spring that slides over the pivot arm that slides through the frame.  The bike in question is a '78 750K.  It seems like this spring is impossible to install to make it function like it is suppossed to!!!  The pictures in the manual don't seem to correspond to what I'm looking at!
I'm going to have a coronary if I can't figure this out!!!
K8 people please help!!!
1978 CB750K - 836 Wiseco kit, 4-1 Kerker Exhaust, Web cam (63b grind), HD valve springs, polished stuff.  Comfortable.
1975 BMW R90/6 - tight
2002 RC51 - Jardine slip ons.  Uncomfortable.
Austin, TX
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: K8 effng rear brake lever return spring!!!! help please!
« Reply #1 on: March 15, 2006, 12:56:50 PM »
I remember doing alot of fiddling around for quite some time with that on my bike as well.
Here's a pict. hope it helps........keep trying, it will only work the one way you haven't tried yet/
Offline hevykevy420
« Reply #2 on: March 15, 2006, 01:09:16 PM »
Thanks for the pic!!!  This site is unbelievably good!!
It appears that the arm at the end of the shaft in your pic points upwards, correct???  And your bike is a K8 too, so I guess mine has to reassemble the same way...correct???  Just want to confirm.
I thought it went down, when I tried it up it seemed to bump into the frame when the foot lever is depressed.  I guess me needs to tinker some more.
thanks a billion!!!
Austin, TX
Offline hevykevy420
« Reply #3 on: March 16, 2006, 08:25:07 AM »
OK- I got the spring installed correctly last night and the rear brake seems to be operating.
Thanks all for the help and pic seaweb!  :) :) :)
Austin, TX
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #4 on: March 16, 2006, 09:48:23 AM »
Glad I could be of help.
