Author Topic: 1976 cb550k fuel hose diameter  (Read 4160 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: November 22, 2010, 09:10:06 PM »
I had to cut my old fuel lines off while doing a carb clean. They were ratty and in need of a swap. But the replacement hose diameter I had ordered is too large. Can someone tell me the correct size hose - possibly both internal diameter and if there is a type recommended.
I just spent 10 minutes withthe fiche bulk hose section. Headache!
The type I bought was from bike bandit, and it's translucent and not rubber like the old ones.  It's stiffer.  Not sure if putting non-OEM hoses on (even correct diameter) will adversely effect the fuel flow.
Thanks in advance
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Re: 1976 cb550k fuel hose diameter
« Reply #1 on: November 22, 2010, 09:36:31 PM »
5.5mm
« Reply #2 on: November 22, 2010, 09:38:53 PM »
If you don't use the correct size, you may leak fuel.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #3 on: November 22, 2010, 09:41:10 PM »
Thanks so much.
Does the material make a difference?  The new stuff I got doesn't seem insulated like the old rubber kind.  It's just not as thick.
I definitely want to make sure I've got the right type.  But was hoping I didn't need to pay OEM prices.
~Sophocles
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: November 22, 2010, 09:47:37 PM »
I recently got the ordinary black hose from here. I was happy to pay the price to be sure of no leaks.
http://www.davidsilverspares.co.uk/tubes/
You could try your local dealer to check cost, the part numbers are listed on the page.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #5 on: November 22, 2010, 09:50:11 PM »
I'm not familier with the bikebandit product, but doubt either are "insulated"! Sounds like a cheap replacement.
« Reply #6 on: November 22, 2010, 09:51:09 PM »
If you don't use the correct 5.5mm I.D., the hoses will either split because you used too small diameter or fall of and/or leak because the next regularly available popular size is 1/4 inch.  For the latter you will need clamps at each nipple.
Personally, I would never use 1/4 inch again (I did 20 years ago). I got some 5.5mm through the Honda dealer after being disappointed by the 1/4 stuff.  I think all the Japanese bikes used 5.5mm at some time.  So, other dealers might be an option.
Of course, after the apocalypse, you'll adapt whatever size you can find.  ;D
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: November 22, 2010, 09:53:10 PM »
It turns out the kind I got was "racing line" fuel line.  It's indeed 5.5 mm, but not black and rubbery like the old stuff I had on there.
I definitely don't need racing anything, but it may work for the time being, until I get get the type linked by Frosty.
Appreciate the help.
~Sophocles
« Reply #8 on: November 22, 2010, 09:55:17 PM »
I hope it's not the stuff that hardens to steel consistency after a year.
BTDT
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #9 on: November 22, 2010, 10:02:23 PM »
I think I'm just going to look for the black 5.5mm.  No need to mess with it.  Fuel...It's the lifeblood after all...
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #10 on: November 22, 2010, 10:07:15 PM »
Correction:  it's 1/4" diameter!  Damn it.  Chalk it up to the first parts order I made.  Stupid.  I have some clamps - but you are saying this still leads to problems, unless the apocalypse comes before I get new stuff???
~Sophocles
Offline Frostyboy
  • Circa 1951
« Reply #11 on: November 22, 2010, 10:15:10 PM »
BTDT
What I love about this forum is not just the technical info about our bikes, but every now & then I pick up other useful information.
I had no clue what TT meant by "BTDT" so I had a google & found this.
http://www.internetslang.com/
TFTI  ;)
We haven't met yet.
[CB550F1]
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #12 on: November 22, 2010, 10:17:46 PM »
I was wondering what that meant!  I was about to look it up.
~Sophocles
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #13 on: November 22, 2010, 10:28:52 PM »
When this is all over you should consolidate all your threads in a "how to get a CB550 running: a practical guide."  ;D
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #14 on: November 22, 2010, 10:46:54 PM »
I might just do that.  All you great resources on here have been incredibly gracious, but I know I often feel guilty about having to have one of you tell me how to do the most simple things.  It might be good to have a noob 101 thread.  The FAQ is great, but sometimes even that is over the head of the uninitiated.  Especially some common terms, that don't jive with the manual terminology.
Maybe it can be like: "you know you are about to make the most basic mistake, well, I just finished doing that incorrectly, here's how you can skip that gaff." :)
And I could add the Internet term primer: DHSADQ (d%#khead, stop asking dumb questions!)
« Last Edit: November 22, 2010, 10:49:11 PM by Nortstudio »
~Sophocles
Offline db22
  • Old and in the way.
« Reply #15 on: November 23, 2010, 04:42:16 AM »
+1 on the "noob 101" thread idea!
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline DavePhipps
« Reply #16 on: November 23, 2010, 05:06:25 AM »
Hey, at least you're taking the time to make sure everything works.
One person I know bought a used bike that ran rough and has never tried to make it better.
He's always running on half choke, and his brake fluid is almost black with age and contamination.
Asking how to do something is always better than ignoring problems with the bike.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #17 on: November 23, 2010, 06:00:17 AM »
Best I've seen is
DILLIGAF
Does
It
Look
Like
I
Give
A
F**K
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #18 on: November 23, 2010, 06:17:06 AM »
Agreed.  My first goal has been to make this beast safe.  The PO obviously let certain things go that really shock me sometimes.  It's NYC after all, and there is no reason to add the bike's condition to the list of factors that make driving in this city a challenge.
But I have to admit, I'm ready for some of the fun stuff.  I have been racing the clock - both weather and daylight savings, to make sure I get the majority of this done before the freeze sets in.
Soon enough....soon enough.  Patience.
~Sophocles
« Reply #19 on: November 23, 2010, 06:23:09 AM »
Nort - at this rate, you will be a "Master" in no time and then it will be you helping the noobs with all their DFQ's!!!
*DFQ = dumb f'ing questions!
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #20 on: November 23, 2010, 06:26:32 AM »
I swear there was a question posted yesterday that was really simple, and I was so excited to answer it - to finally give back to the forum!!!
Someone got to it, just before I did and with a perfectly good answer.  Damn!
I do believe that it will have been a rewarding few months when all this is behind me. But after finding a few of these "quick fixes" the PO left for me, I'm ready for those few months to be over :)
~Sophocles
Offline tango911
« Reply #21 on: November 23, 2010, 06:46:44 AM »
either way you still get the Kudos Nor, not having a garage and living in NY working on your bike on the curb, is crazy.  Keep up the good work.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Trav-i
  • Has finally become an
« Reply #22 on: November 23, 2010, 11:00:37 AM »
FWIW,
Fabricator and myself use braided VW fuel line.  The stuff they used on the air cooled motors, I think it's 5 or 5.5mm.  It fits so well that there is no need for clamps, and the only ways to get it off is to cut it or dab a little gas on the outside and it will release.  We get our line from a local VW resto shop.
Forum member #9962
1992 GL1500 Interstate
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #23 on: November 23, 2010, 11:12:04 AM »
Good tip.  Thanks.
~Sophocles
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #24 on: November 23, 2010, 11:15:05 AM »
Best I've seen is
DILLIGAF
Does
It
Look
Like
I
Give
A
F**K
Bryan
That's a close second to WOFTAM
A = Waste Of Fcuking Time And Money.  ;D
