Author Topic: 79 CB750F Front Dual Disc Brake Set Up on 78 CB750F  (Read 1416 times)
Offline SigEpRider
« on: November 25, 2010, 12:02:00 PM »
Fellow CB750 Aficionados
I recently purchased a 78 CB750F that the previous owner turned into a bobber.  He completely stripped the front end.  All I basically have is the forks, triple trees, wheel, and axle. My plans are to turn this bike into a cafe racer with some slight restoration.
It is proving difficult to find a complete front dual disc brake set up.  I found a set up on eBay, but it is for a '79 CB750F.
Would this set still bolt up a and work on my '78 CB750F.  I will still need a master cylinder and brake lever.
Any help is appreciated and Happy Thanksgiving
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180588493913&ssPageName=STRK:MEWAX:IT#ht_500wt_956
Offline brandEn
Re: 79 CB750F Front Dual Disc Brake Set Up on 78 CB750F
« Reply #1 on: November 25, 2010, 12:17:29 PM »
pm sent
Offline SigEpRider
« Reply #2 on: November 26, 2010, 09:51:00 AM »
bump
Offline mick750F
« Reply #3 on: November 26, 2010, 12:10:35 PM »
   It will work but you also need the caliper mounting brackets from the dohc, they are often sold with the calipers. The brackets and calipers from the '79-'82 CB750F/900F will work. Other Honda bikes used the same caliper but with different brackets. With all of the right parts it's a simple job, everything bolts right up and you have improved braking with the dual piston calipers.
Mike
Glosta, MA
Offline brianmac
« Reply #4 on: November 29, 2010, 08:16:54 PM »
any body know?
u seem to know ur stuff with these old hondas, i have a 1978 cb750k , do u no if a 81cb750c dual disc front end will fit, or what needs to be done.  the 81 has roller bearings.
i do have a  comstar wheel set also with dual discs it seems the 1981 is like an 1/8 inch wider triple trees
Offline SigEpRider
« Reply #5 on: November 29, 2010, 09:22:05 PM »
I found a nicer front caliper assembly from a 1980 cb750f. I'll be able to tell you how the I install went. I could even post pics and anything I learned. Stay tuned.
