Author Topic: dissasembling motor trouble  (Read 915 times)
Offline wicat
« on: November 25, 2010, 04:04:00 PM »
Hey guys im rebuilding my 73 750 motor and i cant figure out how to get the chain off the cam. I followed the books imstructions but its not working. I was wondering would it be worth while to cut the chain then replace it
Offline CrankyOldGuy
  • Wish I was a
Re: dissasembling motor trouble
« Reply #1 on: November 25, 2010, 05:02:02 PM »
wicat,
Which book are you following?
Have you removed the cam chain tensioner holder, the cam sprocket mounting bolts, the rocker arm shafts and rockers? If you have, you should be able to remove the cam chain from the sprocket, and then slide the cam out.  Before sliding the cam out slide something through the chain such as a metal rod to keep it from falling into the opening in the head/cylinder.
Harry O.
750 K1 Original Owner
Offline q2418130103p
« Reply #2 on: November 25, 2010, 07:11:07 PM »
I think the hardest part is to rotate the camshaft in order to remove the cam sprocket mounting bolts.
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline wicat
« Reply #3 on: November 25, 2010, 07:23:24 PM »
I have the cam sprocket losse off the cam and the rocker arms are losse as well. It seems that the cam chain is lose but not enough to slip off the sprocket. The book i have is white cover and red lettering with a guy ridding a honda bike. Im not sure what its called but it came with the bike
Offline SOHC Digger
  • I'm not an
« Reply #4 on: November 25, 2010, 07:56:33 PM »
Again, make sure you remove the cam chain tensioner.
Offline wicat
« Reply #5 on: November 26, 2010, 02:21:21 AM »
Chain tensioner is out. Still no luck
« Reply #6 on: November 26, 2010, 02:54:53 AM »
remove the cam sprocket bolts and wiggle it about a lot,itll come off,replacing it is harder,with the timing and all.
Offline mick7504
« Reply #7 on: November 26, 2010, 03:06:35 AM »
Definately replace the chain if you're doing a rebuild.
It will come off with some patience.
If I was you
I'd be worried about me.
