Author Topic: DWMS RACING CB550F SUPER REVERSE PORT! NEW ENGINE COLORS AND PHOTOS!  (Read 117140 times)
Offline fastbroshi
  • Puppet
Re: DWMS RACING CB550F SUPER REVERSE PORT! RIM PHOTOS!
« Reply #225 on: January 29, 2011, 03:11:50 AM »
Joey I can tell you the 550 frame width at the swingarm pivot is VERY close to the stock width of a late 90s Honda CBR 600 (F3 I believe) arm.   And the rear wheel that goes with the same swingarm tucks in nicely.   Frame would probably need a little modification though.   Yours look like a pair of later CBR wheels, albeit widened a bit.
Just call me Timmaaaaay!!!
Offline Syscrush
  • Sold. :(
Re: DWMS RACING CB550F SUPER REVERSE PORT! INTAKE PHOTOS!
« Reply #226 on: January 29, 2011, 08:13:39 AM »
I am also thinking about building a nice braced tube one.
;D ;D ;D
Offline joeyputt
  • The green flag sets me free
    • www.dwmsracing.com
« Reply #227 on: January 29, 2011, 06:26:55 PM »
Brothers I think I am going to lower the bike a couple inches and build the front end of the frame with close to stock rake as I like the look of a close front wheel and this bike will already look roomy up front without having the exhaust up there!
I have always thought the rear wheel was too far forward on these bikes so I will definately be running a longer swingarm than stock.
Here is a photo of the front end I am using, it is a KYB 43mm setup.
In this photo the rim is sitting in the stock location and you can see how much clearance there is for the carburetor.
Joe - Owner/Operator of DWMS Racing World Class Engine & Motorcycle Building www.dwmsracing.com
Facebook https://www.facebook.com/joe.dwmsracing
Offline popssss
Re: DWMS RACING CB550F SUPER REVERSE PORT! FRONT SUSPENSION PHOTOS!
« Reply #228 on: January 29, 2011, 07:03:11 PM »
Very nice....I'm going with a similar color scheme with gloss black, and that same Orange/rust look....
« Reply #229 on: January 29, 2011, 07:20:44 PM »
Try dropping the triple trees 3 or 4 inches.. high pipe bikes need far less clearance.., I cut the stand mount and relocate it..
« Reply #230 on: January 30, 2011, 12:05:16 AM »
I think a more angled up manifold with 2 down draft carbs would look cool as well, with the stacks pointing straight up.... ;D
Just don't ride it in the rain.... :o
Offline ivanhoew
« Reply #231 on: January 30, 2011, 01:08:59 AM »
brilliantly entertaining thread ,started off my sunday in an excellent way .thank you brother joey .
incedentally i dont get any problems with this underseat pipe ,it is turboed ,which means a lot of heat is taken out by the turbo , but it is .5mm inconel formula 1 piping ,so it conducts a lot of heat through its walls .have a look at the vid youll see how close it is ;;
i think you'll be fine ,you could allways make a polished engraved heat shield for it ;)
regards
robert
just do it .
Offline joeyputt
« Reply #232 on: January 30, 2011, 05:06:50 PM »
Today we used the tank from my dads 550 and finished setting everything up to see what the bike would look like and to get measurements so I can start building the frame.
The engine and tank are going to be a 1 1/2 inches higher than what they are in this photo.
Offline Raef
« Reply #233 on: January 30, 2011, 05:13:57 PM »
looks like it's time to start playing connect the parts (dots)
Offline Syscrush
  • Sold. :(
« Reply #234 on: January 30, 2011, 05:41:11 PM »
Very promising.  I would like to see that swingarm shortened by 3-4", though.
So that the swingarm pivot works with that 17" wheel and a level swinger?  That will look nice.
Offline Kanticoy
  • Mad Science!
« Reply #235 on: January 30, 2011, 05:53:30 PM »
+1.  Looks great, but very long.  If that's what you're going for that's cool, but I envision more "racer" than "bobber", and the stretch is definitely leaning toward bobber.  Either way though....AWESOME!
Offline joeyputt
« Reply #236 on: January 30, 2011, 08:12:00 PM »
Brother Kanticoy I was originally going to build a cafe style bike but have made the final decision to go with more of a pro street look.
Offline Zaipai
    • My Home page
« Reply #237 on: January 30, 2011, 08:16:38 PM »
One word... Yummy!!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Syscrush
  • Sold. :(
« Reply #238 on: January 30, 2011, 08:19:04 PM »
With the 190 that could be quite cool.
Re: DWMS RACING CB550F SUPER REVERSE PORT! NEW PHOTO!
« Reply #239 on: January 31, 2011, 08:16:37 AM »
Moving the arm ahead till pivot lines up to frame hole will shorten it 2.5 or 3 inches..
 If you shorten the arm, with any welding, you should re heat-treat it.. a lot of hassle..
 Lokks good I like the streetracer look..
Offline joeyputt
« Reply #240 on: January 31, 2011, 04:54:14 PM »
Now that I have made a final decision on the rims and suspension I can start building the frame so I bought the tubing and a new tubing bender today.
Offline q2418130103p
« Reply #241 on: January 31, 2011, 05:08:05 PM »
Looks like the harbor freight colors ;-)
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline joeyputt
« Reply #242 on: January 31, 2011, 05:39:16 PM »
Brother they had it on sale and it looks to be very well built and really heavy duty, I will let everyone know how it works tomorrow!
« Last Edit: January 31, 2011, 05:42:48 PM by joeyputt »
« Reply #243 on: January 31, 2011, 05:46:25 PM »
Cool, there sales are sometimes great.  I got their 20 ton press for ~$140. And their 10 lb soda blaster for $35.
Offline Raef
« Reply #244 on: January 31, 2011, 06:03:36 PM »
I have one we got several years ago just like that. it's not the easest thing to bend pipe with, but if you tinker with it and take it slow you can bend pipe with it.
I don't know what the smallest manderal you got or what size pipe you are working with. The best trick I can tell you easaly is to use the next size smaller manderal than the pipe you are bending, that is unless the have adjusted the sizing since I got mine.
Mark
Offline Kanticoy
  • Mad Science!
« Reply #245 on: January 31, 2011, 07:09:43 PM »
Yep.  Joey, if you shim the tubing with sheet metal in the dies with that bender they will make a much better "kink-less" bend.  Those dies weren't designed to compensate for the bends (i.e. thinning toward the ends of the die).  I used one for years and then my wife bought me a JD squared model 32 for christmas.  I am a lucky man!  :D
« Reply #246 on: January 31, 2011, 07:17:36 PM »
 Those look like pipe or conduit dies, not the sizes of the frame tubes..
Offline Kanticoy
  • Mad Science!
« Reply #247 on: January 31, 2011, 07:43:30 PM »
They are, that's why they need to be shimmed.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #248 on: January 31, 2011, 07:55:27 PM »
This benders are pieces of #$%*.. good luck getting good bends with that. You need one of these...
 ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Flying J
« Reply #249 on: January 31, 2011, 10:36:54 PM »
or if your the kinda of guy that likes to build things.... ;) check this website out.
http://www.gottrikes.com/Tube_Bender.htm
