SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
point adjustment how to
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: point adjustment how to (Read 1356 times)
chunksmydog
Guest
on:
March 16, 2006, 12:51:49 pm »
whats the easiest way nto gap my points ? will not start but turns over.aany advice would be appreciated.
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Re: point adjustment how to
Reply #1 on:
March 16, 2006, 12:55:28 pm »
Have you a manual? It's a worthwhile investment.
Or, try the FAQ
http://www.sohc4.us/forums/index.php?topic=5752.0
Logged
cbfreaky750
Guest
Reply #2 on:
March 16, 2006, 12:57:44 pm »
you need a set of feeler gages set the gap betweet your points to 12-16 thousanths of an inch there should be a lock screw you loosen to ajust them also make sure they are clean and not pitted
Logged
jdpas29
Hot Shot
my bike is 100% sandcast!!
Reply #3 on:
March 16, 2006, 03:01:20 pm »
also... make sure the surfaces of you points are clean and free of corrosion. i use a piece of very high grit aluminum oxide sandpaper just to very gently remove corrosion prior to setting the gap. fold the paper in half and slid in the gap. wiggle gently until metal is purdy.
then set you gaps.
Logged
cars are gay.
eldar
Guest
Reply #4 on:
March 16, 2006, 03:15:26 pm »
set them at the smaller gap if possible. this increases dwell time which allows the coils to charge just a bit more so you get a bit stronger spark.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
