Author Topic: Engine test stand: need input  (Read 897 times)
Offline timdhawk
  • 1978 CB750K
« on: November 28, 2010, 03:24:25 AM »
I want to build a test stand for my motor (and subsequent ones) before it goes back into the bike after a rebuild. What would be the minimum i would need to make this work?
-oil tank
-gas tank
-wiring harness
-coil pack
-battery
-tach
-ignition switch
-throttle assembly
-exhaust
anything else? I just want to be able to start, run, and basic bench tune the motor.
thanks
In deeper than I should be...
KingCustomCycles.com
Re: Engine test stand: need input
« Reply #1 on: November 28, 2010, 05:07:07 AM »
An oil pressure guage might give you some security.  Also, extensive bench running at higher power settings will require some cooling airflow.
« Reply #2 on: November 28, 2010, 06:16:40 AM »
I have an old 750K frame with the front neck cut off that I have been looking at to weld-modify into an engine test stand.Should be easy to mount oil tank etc. and I could take off the head in frame-WOO HOO  :D  What are you going to use ??    Eric   Edit: Only downside is that these engines will idle and rev nicely,only show midrange and other tuning problems out on the road under a load.
« Last Edit: November 28, 2010, 09:58:02 AM by ekpent »
Offline paddy paul
« Reply #3 on: November 28, 2010, 08:44:31 AM »
A large fan to cool  the engine while it's running
Offline kerryb
  • Not a very
« Reply #4 on: November 28, 2010, 10:03:25 AM »
I too have been considering a test stand, all of the above looks good.  What would be an easy way to put the engine under load?  A chain drive water pump, or a BIG fan blade.
What do dynomometers use?
« Reply #5 on: November 28, 2010, 10:00:25 PM »
ive run 500/550s on the ground,just to sync then compression test,as posted there is no real load on the engine so flat spots and backfires might not/wont show up,i just do it to see if a motor smokes or knocks.i ran this one with no exhaust for about 4 or 5 minutes,what a racket.
« Last Edit: November 28, 2010, 10:04:42 PM by dave500 »
Offline timdhawk
  • 1978 CB750K
« Reply #6 on: November 29, 2010, 04:22:36 PM »
thanks for the replies. I just want to be able to start it, check for leaks and tune it for a good idle so I know it will not have to come back out once it goes in the bike. I'll keep ya posted.
« Reply #7 on: November 29, 2010, 11:08:03 PM »
with the engine on the ground a 4-1 header will not go under the engine,ive just bolted them on upside down for any test run.
