Author Topic: 350 hartail. its gonna be low  (Read 2381 times)
Offline mack82
« on: November 28, 2010, 02:34:15 PM »
workin on a custom 350.  anyone know of a 17 or 16" rear wheel setup that works with the 350?
Offline shaunzo
Re: 350 hartail. its gonna be low
« Reply #1 on: November 28, 2010, 02:59:52 PM »
looks cool!  love the angles by the downtube.  hope you plan on reinforcing those axle plates...
2007 kawasaki versys 650 - everyday
2008 xl1200n nightster - somedays
1981 cm400 bobber - somedays
1983 cm450 - nodays (gf's)
1982 kz1000j2 - a project
1976 cb750k - project bike
1971 norton commando 750
Offline COMB2
« Reply #2 on: November 29, 2010, 06:37:04 PM »
Cool I like hardtail anything.
Don't throw the trail out of wack lowering the rear to much
Offline mack82
« Reply #3 on: December 13, 2010, 05:07:27 PM »
the rear end is pretty much done except for the fender.  anyone know what the best way to get rust out of the tank?  any suggestions would be helpful
Offline COMB2
« Reply #4 on: December 13, 2010, 05:20:08 PM »
electrolysis
Offline BruceDeuce
« Reply #5 on: December 13, 2010, 05:25:23 PM »
Mack where you from in NJ? Im in Howell. Bruce
78 Honda 550 Four (K)
79 XS650 Special
72 Suzuki TS400J Apache
72 Kawasaki G3SS 90
73 Aermacchi X90
86 Honda 450 Rebel restored
03 HD Deuce Screaming Eagle
Yamoto 50cc Quad
06 Loncin 110 Quad
85 LT250EF Quadrunner
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #6 on: December 13, 2010, 07:13:15 PM »
electrolysis
This is good, but I think they make a rust converter that works with gas tanks as well.  Por 15 makes something
Offline mack82
« Reply #7 on: December 14, 2010, 12:58:33 PM »
im in Long Valley
Offline BruceDeuce
« Reply #8 on: December 14, 2010, 05:21:19 PM »
I haven't tried it but I understand vinegar works for rust as well.
79 XS650 Special
72 Kawasaki G3SS 90
73 Aermacchi X90
Yamoto 50cc Quad
06 Loncin 110 Quad
Offline hapakev
  • Your Standard
« Reply #9 on: December 16, 2010, 08:10:53 AM »
"Works" toilet bowl cleaner.  Does wonders.  Just get a rubber plug/cork from Home Depot and a bottle of this stuff from Walmart, for like $2 or less, and cork and fill your tank.  Top it off with water and let it sit for 1-2 hrs and check it with a flashlight.  If there is still rust, let it sit.  I put in some nuts inso I could shake it up and i put on the gas cap to flip it over and get the top side too.  After you empty it, rinse it thoroughly with water and then coat the inside with wd40 or whatever lube you are comfortable with using, unless you can put it on your bike and fill it with gas.
Smoking Jack
1978 CB750F(ish)
Offline mack82
« Reply #10 on: December 17, 2010, 03:30:02 PM »
ok man ill try it thanks
Offline mack82
« Reply #11 on: January 19, 2011, 05:11:03 PM »
its ready for paint.
Offline cdoggy81
« Reply #12 on: January 19, 2011, 08:27:19 PM »
Looks cool & I like the down tubes as well.
Anyone else think it will crack at the axle plates... I know shaunzo saw it too...
Offline wannabridin
  • -Garrett
« Reply #13 on: January 20, 2011, 10:30:24 AM »
he could add some curved gusset plates to help distribute the forces over a larger area.  i don't see TOO many problems with his setup, but if any arise, they will happen here.  very large concentration of forces are to be had here, so hopefully there won't be any problems.
Offline Raef
« Reply #14 on: January 20, 2011, 10:37:08 AM »
Ha Ha, I love "the works" its my favorite carb cleaner as well, I always get sneers when I mention it tho.
Mark
Offline Raef
« Reply #15 on: January 20, 2011, 10:48:06 AM »
I am assuming you have a wire welder or access to one, I would fill in the areas pointed out earlier, using the wire welder taking several passes letting the heat build up and cool slowly you can then smooth and shape the area to flow a little better anyway you desire.
this will also take out some of the temper from the factory part making it more likely to flex or bend than crack or brake.
just my two cents
looks pretty similar to a project I got going, I started to do the same thing to the point I cut up the swing arm, I then went a little different direction.
good luck
Mark
« Last Edit: January 20, 2011, 10:49:47 AM by raef »
