Author Topic: Terminal Cleaner  (Read 5060 times)
Offline Boner
Terminal Cleaner
« on: November 28, 2010, 03:07:37 PM »
Okay Im old school and maybe you kids know this #$%* but up until now I have always done the following to clean electrical terminals.
1) dip the terminals in muriatic acid then wash off with water and then spray with electrical contact cleaner.  The results are great! however the technology is low and the process not user friendly.
I have since tried a more user friendly approach
2) Spary the terminals and connectors with CRC Battery Cleaner and leave for several hours then wash with water and clean with electrical contact cleaner.
This new method gives the same results and is more user friendly.
Hope this helps.
1971 Honda 750
1950/64 Norton 500 single in Featherbed
1964 Norton 650ss
1974 Trident
1968 500 Trumpet
1971 Commando
3 x Suzy T20's
1997 Triumph Trophy
Offline cookindaddy
  • I sure love this bike!
Re: Terminal Cleaner
« Reply #1 on: November 28, 2010, 03:46:55 PM »
I am interested. What is CRC battery cleaner?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #2 on: November 28, 2010, 03:53:29 PM »
Sounds like a plan, thanks of the tip.
Offline myhondas
  • Not really such a
« Reply #3 on: November 28, 2010, 03:55:54 PM »
CRC makes a lot of spray cleaners and such.  I have been using the 336 cleaner for years.  Great stuff.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline cookindaddy
« Reply #4 on: November 28, 2010, 04:35:00 PM »
Offline Boner
« Reply #5 on: November 29, 2010, 07:48:48 AM »
Battery cleaner is the stuff you spray on your battery top to neutralize the acid and clean the battery , you then wash it off with water.
It does the trick but after several test area's I did find the Muriatic acid was better but I will stick to the battery cleaner.
1971 Honda 750
1964 Norton 650ss
1974 Trident
1968 500 Trumpet
1971 Commando
3 x Suzy T20's
1997 Triumph Trophy
Offline Kong
« Reply #6 on: December 04, 2010, 04:57:34 AM »
I use a small wire brush, shaped like a toothbrush.  You can buy them for a couple of bucks at Lowe's, steel or brass bristles.  Compared to juices there is no waiting and the brush does a good job.
PS:  Somewhere in my mind I asked myself this question as I read your post:  What happens when muriatic acid and sulfuric acid come in contact with each other?  Is it like when M-acid comes in contact with chlorine?
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Old Scrambler
« Reply #7 on: December 04, 2010, 01:03:47 PM »
The fumes from M-acid will peel chrome.........don't ask how I know........just look at my front fender and rim after a bottle of M-acid leaked in my shed about 10-feet away from my bike.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline willbird
« Reply #8 on: July 10, 2011, 03:38:24 PM »
Also M acid if in your garage will rust every single steel/iron thing in there...I have a jug around, but I store it OUTSIDE the garage.
