Author Topic: help  (Read 1490 times)
Offline BobbyRc51
help
« on: November 30, 2010, 02:18:00 PM »
I bought a 1974 cb550 few months back and it is having front end problems.  The front end isn't original and has dual disk.  The speedo binds and has snapped a cable.  Can anyone identify this front end so that I can order the correct parts or just replace the front end with the original?
Also my front brakes also don't release(relax) after use so they are always grabbing make the bike hard to move around or drive.  Is this the master cylinder or the 4way joint that is the the issue.  I cleaned and calipers and the master cylinder with no luck.  any help would be great!!
Bobby
Thanks,
BobbyRc51
Offline KeithTurk
Re: help
« Reply #1 on: November 30, 2010, 04:52:25 PM »
That looks like a stock front end with an additional disc added on the right side.... which is where the speedo fits.... there is a thread somewhere in here that talks about "how" to build a dual disc front end.... and it looks exactly like yours...
K
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: help
« Reply #2 on: November 30, 2010, 05:21:58 PM »
My guess is that the right brake caliper was not shimmed properly. You can also file off a bit of the lower caliper mount on the left fork to correct this.
Previous owner probably just bolted it up without the needed corrections.
Pull it a part and post a photo of the speedo drive side. There are tricks that need to be done to that as well to make a fully functional twin disk set up.
Here is some reading for you ;)
http://forums.sohc4.net/index.php?topic=53532.msg573976#msg573976
http://forums.sohc4.net/index.php?topic=77033.msg859365#msg859365
Offline BobbyRc51
Re: help
« Reply #3 on: November 30, 2010, 07:11:12 PM »
Thanks guys I will read these strings and also take apart the front end for some pics.
As far as shimming the caliper mount.  This I'm unclear about.  It feels like the front brakes don't release after I apply pressure. Is that a clearence problem or master cylinder problem or something else?
Thanks
bobby
Thanks,
BobbyRc51
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: help
« Reply #4 on: November 30, 2010, 07:17:06 PM »
read......... and then disassemble young skywalker ;)
Re: help
« Reply #5 on: November 30, 2010, 08:09:33 PM »
I'm not well versed in the 550 but the calipers look to be 76 to 77 750F or 77 to 78 K Note ther center location on the bleeder and inlet fitting also lack of fins.
Offline 333
  • Time for change
Re: help
« Reply #6 on: December 01, 2010, 07:33:38 AM »
The brake not releasing may be a separate issue.  You may have to rebuilt the master cylinder.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: help
« Reply #7 on: December 02, 2010, 10:17:38 AM »
You don't want that dual disc set up anyway. Send it to me. I'll take care it  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline BobbyRc51
Re: help
« Reply #8 on: December 03, 2010, 08:53:57 AM »
The master cylinder is bad, I will rebuild it and it should work properly then.  Does anyone make a brake line kit that goes from the master cylinder to the calipers, bypassing the four way joint?
Thanks
Thanks,
BobbyRc51
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: help
« Reply #9 on: December 03, 2010, 10:09:33 AM »
You can use a longer dual banjo bolt on the M/C and using longer lines to go direct to calipers
Offline BobbyRc51
Re: help
« Reply #10 on: December 04, 2010, 05:51:05 PM »
The the caliper end isn't a banjo style fitting.  Any suggestions?
Thanks,
BobbyRc51
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: help
« Reply #11 on: December 04, 2010, 07:47:26 PM »
No, the one at the M/C is. There are a number of ways of doing it,  fittings etc.
I suggest you thoroughly read the links I offered, and try a search off the main page for dual brakes. :)
Lots of photos as well.
Offline BobbyRc51
Re: help
« Reply #12 on: December 10, 2010, 08:43:37 PM »
Thank you all for your suggestions.   So far I found that the master cylinder was rusted and leaking, one of the ports was also plugged.  The lines are ok, but what I found that was disturbing was on the joint down on the tripple clamp.  This was a stock unit with one hose coming and two going down the brake calipers.  When the previous owner did this mod he didn't invest in a double banjo so only one line was getting direct pressure and return.  Not good. I will rebuild the system and purchase the correct banjo bolt for the job.
Thank u all
Thanks,
BobbyRc51
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
Re: help
« Reply #13 on: December 11, 2010, 12:08:28 AM »
Yeah, that would do it ;D ;D ;D
