Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Hey I just bought a 1976 cb750a... My battery is losing power when I ride my bike around because its not getting recharged. I was going to pull the alternator out and take it to a parts store and have some guy test it. Anyway I unbolted the alternator cover which was held on by a bunch of allen cap screws. Everything seemed to be coming apart easily. Then I realized that the wires run deep inside the engine and i can't get them unplugged. can some help me figure out how to access them?
The stator ohms values are the same for all the CB750 engines. The field coil on the "A" engines is about 0.5 to 0.9 ohms less resistance than on the other 750 bikes. The ohms values are shown in the manuals. Check between the Yellow wires for pole-to-pole, 2 at a time (they might look bleached white by now), and there are just 2 field coil wires to measure between. It's pretty simple.
Quote from: HondaMan on December 01, 2010, 11:40:09 PMThe stator ohms values are the same for all the CB750 engines. The field coil on the "A" engines is about 0.5 to 0.9 ohms less resistance than on the other 750 bikes. The ohms values are shown in the manuals. Check between the Yellow wires for pole-to-pole, 2 at a time (they might look bleached white by now), and there are just 2 field coil wires to measure between. It's pretty simple.I'm asking this without looking at the Ohms values in the manual so please forgive any obvious ignorance, but does the above mean that converting a 750 alternator into a 290W 750A alternator requires just a different field coil? I have more reading to do maybe.Thanks HMAlan
well I unplugged the rectifier and I checked the 3 A/C wires comming from the stator coil for continuity and I was getting a measurement of like .7 ohms so I'm pretty sure my stator coil is good and i didn't even have to take my alternator cover off again which is nice. Im just now realizing that hondaman covered all this in an earlier reply on this thread. So hondaman I guess I am kinda confused. can you explain how to do that jumpering procedure between the black and white wires on the voltage regulator. Also is there anyway to check for continuity on the field coil without having to take my alternator cover off again?
Damn rare that a stator goes bad. Did it get attacked by road rash or a madman with a hatchet?They don't destroy themselves even with a directly shorted output.Bad field coil I can believe. "Stator problem" makes the eyebrow raise inquisitively.
