The SOHC/4 Patch & Pin Set is available at the SOHC/4 Store.
SOHC Digger: Are those the 4 O-rings on the top near the nuts in this picture?
The restrictors are the little aluminum orifaces inside the o-rings next to your cam chain (two of the four mentioned o-rings)
So how heavy is that lump of a motor? Is it possible for one person to wrestle it out? (I'm guessing not.)
These four screws have completely seized up. #3 JIS impact driver not getting me anywhere. Trying some penetrating oil for the next 24 hours since I have other commitments for a bit. After that it'll be heating a rod, applying to the head of each in turn until the oil smokes, reapplying oil and letting cool before trying to remove.
By the way, it's good that you have a nice camera. The shift linkage is where I seem to have the most problems figuring out on reassembly. No diagram I have seen helps. Take good pictures in this area so you know how your springs go!
[CAUTION... EDITORIAL ALERT! ]Joan's using an Olympus c5050z which is not a bad camera but if she's half as skilled as I suspect (and she were impolite like me , she might tell you that the nice pictures have little to do with the camera and a lot to do with the person behind it. SOHC Digger - I see you're in the Chicagoland area. I'm pretty close (NW Indiana). Maybe we can catch a ride some time.
