Author Topic: J.Webster Designs Phase 2 build....project "SHINOBI".... (Updated 04/19/2012)  (Read 36218 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
Re: Midnight08's Phase 2 build....project name unknown....
« Reply #100 on: February 03, 2011, 09:00:19 AM »
i will definitely give that a shot... only problem is that I am thinking that its most likely metric as it is VW. most of the hardware shops around me dont give 2 cents about metric. gonna go hunting in a little bit hopefully it will come up.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline Raef
« Reply #101 on: February 03, 2011, 09:02:50 AM »
good luck
« Reply #102 on: February 03, 2011, 03:07:27 PM »
my journey to find a brass or aluminum nut was unsuccessful....
another thing i ran into was the fact that i think the CHT sensor that i picked up will not work properly as it is a single wire sensor and not a dual wire. i will still see if i can figure out if this sensor will work for me or not.
on a brighter note, I have wired up the MAP sensor and the IAT sensor and have positive readings from them. when I get back home from running some errands in about 1.5 hrs, i will wire up the TPS and see if i can get some positive readings from it as well. might get you guys a screen shot later tonight.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #103 on: February 04, 2011, 09:39:51 AM »
just a quick update...
I have finished wiring in all the sensors except for the O2 sensor... Everything is communicating properly with the laptop... I probably need some better table values for the CHT sensor that I am using but other than that, I have steady readings across the board with no noise problems.
I should be receiving my fuel rail today, once i get that, I will be able to fully finish off the TB fabrication. I think i am going to do a center feed fuel rail with returnless fuel system.
here are some screen shots of tunerstudio displaying my sensor information in real time.
you can see in the last picture that the sensor information is nice and flat on the installed sensors... no noise....
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline lordmember1969
« Reply #104 on: February 04, 2011, 03:22:03 PM »
Nice :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline 23tbucket
« Reply #105 on: February 04, 2011, 08:22:23 PM »
Midnight; Sorry, I answered a bunch of your questions on 750essess's posts!!!!
JBweld will work just fine to place that sensor in the fins someplace....others have done it this way. They usually make a bracket for the sensor and JBweld the bracket into a part of the head fins some place inconspicuous. With using JBweld, you can always file and sand it off later if needed with no damage.
Aaaaand, I'll bet you are getting quite exited about now? he! he!
...Take care; Clifford
« Reply #106 on: February 04, 2011, 09:13:33 PM »
i think i am going to drill and tap the top fin between cylinders 2 and 3 and install it there...
and yes i am getting VERY Excited!!!
UPDATE!!!
Fuel rail came in today!!! I will get pictures up tomorrow.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #107 on: February 06, 2011, 04:46:22 PM »
Fuel Rail showed up... I am going to be doing a center feed  fuel rail and capping the ends of the rail... i might round the fuel rail slightly on the ends to make it a little more visually appealing. i have enough rail now that if i don't like the first design, then i can make a second.
should be taking the rail, throttle bodies, and injectors in to have them drilled and capped.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline MasterChief750
  • Detonation
« Reply #108 on: February 14, 2011, 02:02:37 AM »
I like the center feed idea. On my car its returnless and it come in from the drivers side. In a hard right turn ill get either a lean code or ping warning on cyl 4. Course the physics of a bike in a turn are a little different. Can't wait to see this project to progress.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
« Reply #109 on: February 14, 2011, 06:30:05 AM »
thanks! I think that the center feed will work out nicely. although I am hoping that there will not be any problems with air getting trapped in the system.
Update: I ordered up my fuel pump today... it is an LTR450 pump. should be here in a couple days and then i can get started on plumbing the system.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Re: Midnight08's Phase 2 build....project name unknown.... (update 02/17/11)
« Reply #110 on: February 17, 2011, 11:22:59 AM »
The fuel pump showed up today... gotta clean iit up and test it out to make sure everything is OK with it. anyone know of any good ways of testing an electronic fuel pump?
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #111 on: March 26, 2011, 01:54:39 PM »
WELL....Work has had me running around like a chicken with its head cutoff, and my Fiancee had to have some surgery. BUT... I am back up and running.
I got my FPR and most of the fittings so that I can get to plumbing the system. I will have to weld up some mounts for the FPR and the Fuel Pump, but that will have to wait till my tax return gets deposited so that I can pick up my new Miller Welder...
I am going to mount the FPR under the battery tray...
The lack of room under the battery box means that i have to get a little creative with the plumbing, but it all works and has enouugh clearance for swingarm movement.
The Fuel pump is getting mounted under the swingarm...
I wanted to get black fittings and black fuel line, but the local shop didnt have exactly what i wanted. but the fuel line and the routing of the fuel line blends in well and doesnt stick out too much.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Midnight, did you think of running one of the newer "small" {lithium?} batteries and then cutting down the battery box and fitting the pump next to the new smaller battery.? There are a couple of threads here somewhere with dimensions for the smaller batteries and a couple of guys are running them with no problems, would sure tidy things up a bit and keep it looking stock.... ;)
Retro, I did look into that, however, the fuel pump is big enough that it would take up 80% of the batt. box, and the length is too much. it wouldnt allow the seat to close. you cant see the fuel pump at all when standing next to the bike. all you see is the fuel line coming up and out of the side.
I will hide everything much better when i build a new frame. mission is to get the bike up and running well before worrying about hiding every inch of the system.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
OK I'm hooked on the idea of EFI. :)  Question regarding the Aeromotive regulator.  It looks like the version with the vaccum port.  I was under the impression that was only required if you are running a turbo.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
it is... however, you can run it without a turbo as well. or you can cap/plug the vacuum port. The only reason that I have this particular regulator is because the local speed shop had it in stock and on sale... and I have had good luck with aeromotive in the past.
The EFI mod is definitely shaping up to be a good one... I still have to figure out the charging system though.... but the benefits are looking to be fun and beneficial
Just so everyone is clear... you have to REALLY want EFI... if you don't have the itch to do this, then don't... I haven't added up the expenses yet, but I am sure I have surpassed the price of a set of CR carbs already.
« Last Edit: March 28, 2011, 06:55:09 PM by midnight08 »
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
OK that makes sense, always good when you can keep money in your own pocket. :)   As for cost, I have no doubt that if you can do all this for x2 the cost of CR's, it will still be a good deal.  Especially given the potential for improved drivability, economy, and maximising performance.
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
Not to mention how f'n trick it'll be.
did a little machining today...
gonna use an old hub to make some hub centric adapter rings for the front CBR 1000RR rotors. first thing to do was to split them in half.
Unfortunately the bearings for the hubs have not showed up yet, so I can not figure out my spacing.
I also pressed out the old CBR 1000RR steering stem...
I also have some solid cold rolled steel stock at the house and decided to play around with it before I order up some aluminum. I still have some learning to do on running a lathe before I attempt the final stem.
I also cleaned up some parts that came with a new QCTP that i got.
Before:
After:
Machining is starting to get fun now that I am getting good results.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline cdoggy81
I like it!!!
thank you good sir!
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline TMHackCB500
  • Just a Hack
Subscribed...
looking forward to seeing how this turns out.  I'll be putting MS in my GTI this summer hopefully. I have thought about doing microsquirt on my seca but the cost would be too high for now...
Keep up the good work!
1982 Yamaha XJ550 Seca, 1977 Kawasaki KE250, 1972 CB500 Four(the newest project and my reason for being here!)
well got a new toy today... needed one to make some brackets to mount the FPR and the Fuel pump to the frame.
Here she is!!!
Millermatic 211 with MVP...
Got some gloves... Miller Arc Armor...These are the BEST welding gloves I have EVER had on my hands...
Got a nice cover to protect the investment...
It also came with some Hobart HB-28 ER70S-6 wire...I am STOKED to try it out... I think the first project is going to be a welding cart.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Tintop
excellent addition, to go with the lathe.
77 CB550 Cafe build
Offline Raef
the auto setting on that machine is a very nice feature, it welds smoother than my millermatic130 and the 200 amp unit but we have had the 200 since about 1980 with no problems
Mark
