Author Topic: J.Webster Designs Phase 2 build....project "SHINOBI".... (Updated 04/19/2012)  (Read 34190 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
thanks man.... I am surprised no one has noticed the oil pressure gauge yet... I guess I accomplished my goal since no one has noticed it yet...
Where is waldo?
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
The pic of the engine with the throttle bodies is now my new desktop background.... ;)
Offline Flying J
Nice work going on here
Offline ozcaferacer
Thanks to RetroRocket I'm back watching this thread.
That bike/work of yours is very cool, and inspirational, as is.
To be honest, I'm heading down a very similar path, and I only hope it works out as well as yours.
[quote ..... i would have WAY cooler stuff...
[/quote]
lol. I am glad you found good use for my pictures retro....
Thank you FF.
Ran into some problems with the bike... some of which I knew I was going to have problems with and other i didn't.
- Charging system isnt even close to keeping up... I rode the bike around the block and the battery died. time for a charging system upgrade...
- bike is currently not starting... trying to diagnose what is going on. something happened when the battery died. possibly corrupted a file in the tune. I reflashed the ECU tonight so we will see if she is back up and running tomorrow.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline fastbroshi
  • Puppet
I seem to remember another member adapting a VFR800 rotor/stator to the end of the CB750 crank.  I'm sure you remember the thread as I think you'd chimed in there as well.
Just call me Timmaaaaay!!!
sure do. looking into other bikes to see what would work as well.
anyone know if the tapers on the crank for the rotor is the same throughout all the years that the SOHC was made? if so, that would be nice as I have a spare crank that I can play with.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline fastbroshi
  • Puppet
PM MRieck, he'd know.
Offline SF
  • I burn gas very well
NICE BUILD, LIKE THE FLAT BLACK PAINT
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
fastbroshi... He would know what? charging system upgrade from another bike?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline fmctm1sw
He was probably talking about the crankshaft info.  MRieck does a lot of motor work from what I gather.  BTW, were you the guy I talked to about the CBO side cover paint?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline lucky
I am very interested in the fuel injection modification.
I do not understand why you want it to be a Mono shock system.
What would the reason be?
Thanks for posting.
Offline lucky
Re: Midnight08's Phase 2 build....project name unknown....
« Reply #187 on: May 17, 2012, 09:01:17 AM »
The medium attaching the two dissimilar metals together must have a lower melting temp than the mating metals. other than tin and mag not many thing fit that bill and are compatible with steel and aluminum
what does the sensor look like?
You cannot weld steel to aluminum.
In the boat building world you can buy blocks of steel bonded with aluminum by high pressure explosion joining process. They use these blocks to weld aluminum wheel houses onto steel decks.
You can machine a special nut with a screw boss to attach to your sensor.
Another common method is drilling a hole through a engine cooling fin and attaching a  aluminum mount plate.
I could just get an aluminum nut and weld it to the aluminum fin... most likely the way that I will accomplish this.
Thanks for posting.
numerous performance reasons for wanting a mono-shock system. to name just a few, ease of tuning (only have to tune one shock vs. two) less un-sprung weight, not having the possibility of manufacturing tolerances causing one shock to be slightly different than its counterpart (having to fight to match the shocks during tuning.)... The list goes on really. but ultimately, I like the look of a mono-shock setup. I will be designing and building my own swing arm to properly utilize the mono-shock setup.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Gotcha!!! I will have to contact him and see if he might know. as for the paint.... I dont think so?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline fmctm1sw
Ok.  I talked to somone a while back that had a brother in law or something that paints something real close to the original olive color...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline crazypj
  • I'm brill, me
Was there a reason you used reverse jaws to make axle spacer or just too idle to switch them?  ;)
Parallel spacer is much lighter but I've been making complete cover/spacer when speedo drive is removed as it looks better (lot more work as well, you have to start with 2-1/2" bar)
Offline crazypj
  • I'm brill, me
Good.  I don't know why, but I get really stressed out when I see casting lines left on project bikes.
Me too, particularly a 'high end custom' (eg, 'Cafe Racer' TV by well known CAR builder)
Before
After
PJ.... The axle spacers are simply there to do their job. I don't know if i mentioned this in a previous post or not, But I am having hubs custom made to the application by a well known dirt bike hub manufacture. Once I have those hubs and I am doing final assembly, I will make some better looking spacers. Right now I am simply focused on getting the bike functional so that I can test the fuel injection properly.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline crazypj
  • I'm brill, me
I read that, sounds expensive to have hubs made?
$4~500.00?
will be well worth it. stronger, lighter, better designed, better bearing selection, will be made to the specifications so that I dont have to have rotor adapters... tons of benefits to it. once i get those, i will make some cool axle spacers that are functional and aesthetically pleasing.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline crazypj
  • I'm brill, me
Sounds real good and should look even better
 I thought you would have hub made to spec so separate spacers were not required
Looking forward to it, I love messing with bits of alloy in lathe/mill  ;)
axle spacers will always be necessary for hub centering and proper axle torquing. I think its gonna turn out real good.
I am thinking about possibly running Performance Machines Black Ops wire wheel hoops laced to my hubs. not sure yet.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline crazypj
  • I'm brill, me
Sorry, I meant rotor spacer not axle spacer.
 I need to take a look at the performance machines rims
Looky looky at what I am working on... Anyone else want a set?
They will be adjustable, with proper folding pegs to allow for kick starting. They will also be set closer inboard on the bike to get your legs tighter up on the bike. As well as being COMPLETELY bolt on with the option of using stock master cylinder/drum brake set up, or using aftermarket (newer style) rear master cylinders.
VISIT OUR WEBSITE!
Facebook:
Instagram:
