Author Topic: CB 650 primary chain tensionerin in to CB 550 ?  (Read 13642 times)
Offline CB500Four
Re: CB 650 primary chain tensionerin in to CB 550 ?
« Reply #25 on: December 20, 2010, 03:32:50 AM »
hey heinz , do you have any shots of the other side of this bracket ... looks like a pretty easy mod as long as you have all the parts (witch i do )
Hey Spikeybike!
I think you will see the surface side of the bracket which touchs the case.
Unfortunately i haven´t a pic which shows this. And the bracket is build in :-[.
But as i mentioned i will do a drawing of the slight modified bracket.
My shown bracket is made of mild steel but the new one will be made
from aluminium 7075 with a third bolt for fixing in case.
As bwaller mentioned you should not grind the tensioner (perhaps a very little bit).
You must cut a relief in the bracket which meets nearly the shape of the tensioner.
Regards, Heinz
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #26 on: December 20, 2010, 11:32:03 AM »
Hey Spikeybike!
Regards, Heinz
I used 7075 with the third bolt. It's such a small piece, and 10mm or so thick (if I remember right). Surely the aluminum will be strong enough..
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline 50BMG
« Reply #27 on: December 20, 2010, 04:36:27 PM »
Would it be better to Heli Arc Weld an Aluminium block in the case rather then drilling -- tapping and bolting ???
Offline paulages
  • 1976 cb735
« Reply #28 on: December 21, 2010, 11:56:33 AM »
Sure, just be careful not to distort the mating surface of the sump pan. The drilling and tapping is not difficult, though welding would remove the hole through the case that needs to be sealed with a copper washer.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline kayaker43
« Reply #29 on: January 06, 2011, 06:53:51 PM »
Anything to take backlash out of the drive train is a good thing. As long as the spring is stiff enough to do that?? I suspect the spring is stiff enough to keep the chain from whipping around but not strong enough to prevent backlash on downshifts.
I wonder about converting to a fixed but adjustable tensioner? Kind of like a manual cam chain tensioner. Shouldn't need adjustment often, and would have a little less drag than a spring. It could eleimnate backlash though..
Offline cwchan
« Reply #30 on: February 03, 2011, 07:15:54 PM »
how much deeper is the 650 pan compared to the 550?  Any exhaust clearance issues?
« Reply #31 on: February 03, 2011, 07:19:22 PM »
It's about 5/8" (16mm) deeper & yea it can interfere with your exhaust.  ;)
Offline CB500Four
« Reply #32 on: February 04, 2011, 04:08:32 AM »
Hi there!
Here are the promissed pix an the drawing.
Iwill fill in some lyrics later.
Regards, Heinz
« Last Edit: February 04, 2011, 04:11:28 AM by CB500Four »
Offline CB500Four
« Reply #33 on: February 04, 2011, 04:13:17 AM »
Next bunch of pix.  ;D
« Last Edit: February 04, 2011, 04:17:29 AM by CB500Four »
Offline CB500Four
« Reply #34 on: February 04, 2011, 04:21:04 AM »
And here is a drawing with some measures.
I hope it will help someone.
As mentioned i´ll do some lyrics later.
Regards, Heinz
« Last Edit: February 04, 2011, 04:23:20 AM by CB500Four »
Offline Raef
« Reply #35 on: February 23, 2011, 05:35:30 AM »
Thanks for sharing guys, you are awesome, I will be adding this to my current 550- 650 motor build
Mark
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #36 on: October 15, 2012, 09:41:03 AM »
Excellent update Heinz.
Thanks for the shop drawings too.
Looking forward to this mod.
Offline lukeyb
« Reply #37 on: March 25, 2014, 01:52:14 PM »
Amazing info guys, thanks! I have a loose primary chain and i plan on doing this mod as a fix (i don't have the time or space at the moment to replace).
I am going to drop the engine out of the bike but keep it intact. How did you guys drill the holes in the casing? It look's like there isn't enough clearance to fit a drill in and drill a straight hole.
