With the 750 Tracy out of the shop and delivered I rolled the CZ in after pulling the pressure washer out and freezing my butt giving in a quick rinse. The usual high around here this time of year is in the low 40's, but in this time of global warming(at least Al Gore said so) it hasn't been much over 32.
I pulled the carb and cleaned it but it really did not need that. Check the photo of the float system, I've never seen anything like it, it is a Jikov carburetor-crude but simple. Also, the photo of the air cleaner gives new meaning to the term sock filter. I guess the PO couldn't find a replacement filter. I'll probably have to continue using it until I can find one. Maybe wash it
. Inside of the tank is clean as can be.
I polished a spot on the headlight with my favorite chrome cleaner-fine steel wool and Simichrome. Looks like it should clean up real well. Side cover looks great with some Krud Cutter and polish.
Put the carb back on, mixed up some 2-stroke(haven't done that for a bike in over 25 years) filled the tank, tickled the carb, kicked twice with the key off, turned the key on, kicked and the bike fired right up.. Let it warm up a bit and took it up and down the street to make sure transmission worked fine.. It does, now I have the work of clean up, fluid changes and greasing bearings. Sent off for title change, may even ride it under vintage tags when it snows...
Will continue to post...Larry
