Author Topic: Tonight's Noob Question: Battery Leaking  (Read 612 times)
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« on: December 08, 2010, 04:20:35 PM »
My battery seems to be boiling over. I am assuming the bike did it before I bought it, as there were spots on my exhaust. The liquid level looks a little low, but I havent added any water to it. Its blown off a few of the plastic caps. I know nothing about electronics, but I have checked with my multimeter and the current seems to match up with what it should be.
So far, I have read that it might be a bad battery, or a bad regulator.
I just got some new to me 4-1 pipes and they already have a splash of battery acid on them that has tarnished the chrome, so any advice is appreciated.
I have considered just buying a sealed battery, but I dont know if it might just explode if its being over charged? Another forum post said a sealed batter worked out but I wanted the collected experience of the sohc4 forum before I made a move.
music
Offline OldSchool_IsCool
  • Really feeling like an
Re: Tonight's Noob Question: Battery Leaking
« Reply #1 on: December 08, 2010, 04:27:42 PM »
Prolly regulator.
Using your multi-meter, take voltage readings at the battery under the following conditions:
- Bike off
- bike running at idle (1000 - 1200 RPM)
- 2000 RPM
- 3000 RPM
- 4000 RPM
- 5000 RPM
Report your results back here.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Kong
« Reply #2 on: December 08, 2010, 05:04:56 PM »
Try oven cleaner on the pipes, but to be honest there's not much hope if the acid has already etched the metal.  You do need to fix the over-charging problem before you get a new battery; no reason to ruin two of them.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
