Author Topic: Removing Valve Springs on complete motor CB550  (Read 11359 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
« on: December 09, 2010, 02:39:26 PM »
getting ready to replace valve spring seals on a cb550 1976. I have a couple of questions:
1 I notice in the manual there are O-rings that seal the valve guides to the head. Should these be replaced and can the guides be removed while the head is still on the motor? I don't plan on taking the motor off the bike to replace the seals.
2 Has anybody ever used one of these tools it looks like it might be the perfect valve spring compressor for the CB550.
http://www.sears.com/shc/s/p_10153_12605_00915017000P?prdNo=8&blockNo=8&blockType=G8
I have my new valve guide seals, valve cover gasket, and 6 new rubber pucks so I think I'm ready.
Thanks.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
Re: Removing Valve Springs on complete motor CB550
« Reply #1 on: December 09, 2010, 02:46:23 PM »
Having just used a tool very similar to that one to do just what you're doing, I can say it is definitely not the perfect tool.  There is very little clearance between the spring and the aluminum of the head, so an automotive spring compressor like that isn't ideal.  The ones like a large c clamp that reach around the head and compress that way would be much easier.
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: December 09, 2010, 02:59:22 PM »
C clamp type won't work. the head is staying on the motor and the motor is staying on the bike. But yeah I was wondering about clearance getting at the spring.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Kong
« Reply #3 on: December 09, 2010, 03:30:23 PM »
You can buy kits that have an air fitting that screws into the spark plug hole into which you blow air to hold the valves up to remove/replace springs.  Its similar to a compression tester fitting but it gives you the ability to blow air into the cylinder and then lock it there with a valve. I'm certain Snap On used to make them, I'm sure others do as well.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #4 on: December 09, 2010, 03:44:36 PM »
Thanks.
having done this on my CB750 (removed the valve springs while the head was still on) I helped a guy here with his CB500. Don't rememebr his handle. He bot a spring compressor external type. But he said there wasn't enough room. But he was able to compress the spring to get the keepers off with the help of his son I think and some screwdrivers. The Oring on the guide is a non-issue, you won't be touching the guides. Just get the springs off, replace the guide SEALS, replace the springs and get on. I simply raised the pistons to TDC on the cylinder i was working on. That was enough to hold the valves closed enought to make the switcheroo. A suggesstion I thoug sounded interesting was to shove some string in the cylinder as you raise the piston up to TDC, that would hold the valves closed even more. Then pull the string out and go to the next piston, one at a time.
Offline lone*X
« Reply #5 on: December 09, 2010, 04:16:41 PM »
If you cant find the air fitting to hold the valves in place during removal of the springs you can also do it the poor mans way.  Take a roll of cotton cord, with the piston of the valve set you are working on at the bottom of the bore, insert the cord into the spark plug hole and start feeding it in.  after a few feet of cord are inserted bring the piston toward the top of the cylinder.   Carefully compress the cordage in the cylinder with the piston until the valves are pressed tight to the head.  Proceed with spring removal.  When done, rotate the piston down a bit and pull the cord out.  Go to the next cylinder and repeat.
Opps, sorry for the repeat of MCriders method.  Guess I didn't read his whole post.  Same method.  We used to do this on big block Mopars that liked to smoke due to bad valve guide seals.
« Last Edit: December 09, 2010, 04:20:17 PM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #6 on: December 09, 2010, 04:37:35 PM »
No problem. This is the coolest thing ever. I did mine 15 years ago. By now there's got to be tons of old inline 4s that could stand to have their guide seals replaced, but everything else is fine. Hope we've helped.
dcil
« Reply #7 on: December 09, 2010, 05:07:25 PM »
+1 on string. works great. I use 1/8 nylon
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: December 10, 2010, 10:19:55 AM »
Damn you guys are good! I plan on doing the rope trick. In fact if I am patient enough I may make a 'How To' thread with pics. Unfortunately my wife gets pissed off when I get greasey finger prints all over her camera. And my camera cost way to much to get grease all over it. Maybe I can talk her into taking pics while I work on it. For kicks and grins I bought this spring compressor for $15 at HF we'll see if it fits. Seems like it may fit into tight places.
http://www.harborfreight.com/universal-overhead-valve-compressor-92900.html
Now all I need is time and a fairly warm day to do this (Unheated garage). I might have to wait until after the holidays. Getting excited for my bike to "kick the habit" if you know what I mean.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline 50BMG
« Reply #9 on: December 10, 2010, 02:48:45 PM »
I bought the 15.00 harbor fright and had no luck with it. there was no room to get it between the head and the spring. I am taking the grinder to the tool this weekend. what tool is the wright tool ?? we cant be the only ones that have this problem
« Reply #10 on: December 10, 2010, 09:21:23 PM »
The forum member I was corresponding with, I forget who, discovered that the tool was too big for the 500 head (though it worked on my 750 head) as well. He realized that with some extra hands ( I think he enlisted his son)  he could just push the springs down by himself, I think maybe some screwdriver levers or such. he indicated it was no big deal and he got the seals swapped out. Wish I could rememebr who it was.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11 on: December 11, 2010, 05:37:00 AM »
I tried that HF tool also, no dice.  Since my head was off, I went the C-clamp route.  To access the retainers when the springs were compressed, I used a short piece (about an inch) of channel iron.  Once compressed, I could use the greased-up tip of large tweezers to manipulate the retainers.
I think combining the rope trick plus an assistant or a leaver to compress the springs plus some sort of "access channel" you should be able to do this with the head on.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: December 11, 2010, 12:39:56 PM »
Nothing is ever straight forward with these bikes is it? Luckily my neighbor builds bike frames so I think I can solicit his help to make a tool or modify the HF tool. I had to modify the HF circlip tool to dismantle my brake master. That worked out. You never know.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline lucky
« Reply #13 on: August 24, 2012, 08:20:21 AM »
Some confusion here.
They want to put on new valve guide seals without removing the cylinder head.
It can be done but you need to make your own tool.
« Last Edit: August 24, 2012, 06:02:09 PM by lucky »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #14 on: August 24, 2012, 04:19:51 PM »
Hey Lucky, do you ever show up to a party when the keg is dry and everyone is already gone home?
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline lucky
« Reply #15 on: August 24, 2012, 06:03:09 PM »
 Do you?
Some forum members may be reading this forum and do want the information.
« Reply #16 on: August 25, 2012, 01:58:21 AM »
hey hey hey,, here i am guys!sorry im late!hey wheres all the beer!!!!
« Last Edit: August 25, 2012, 02:03:20 AM by dave500 »
Offline tino montreal
« Reply #17 on: December 18, 2013, 03:51:19 PM »
Ok, I know this may not apply, but I will try over the next few days and let you know....I used tie wraps to get my valve springsncompressed on my 1990 honda CRX so going to try on my CB500, possibly tonight.
« Reply #18 on: December 18, 2013, 05:51:49 PM »
Ok no way tie wraps will work.....scratch that one down.
« Reply #19 on: December 19, 2013, 09:56:58 AM »
Going to use C-Clamp and modified Socket...will post photos once tried, tested tonight.
« Reply #21 on: December 19, 2013, 10:22:21 AM »
C-clamp wont work in this application as he's not removing the head.
But for those interested, an automotive O2 sensor socket already has the cutout.  no mod req'd.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #22 on: December 19, 2013, 10:33:36 AM »
Wow this is an old thread. Yep, removed the head and let someone else do the valve work. :)
I forgot about the keg party comment  ;D poor Lucky we like to pick on him  ;)
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline goldarrow
  • one day, i'll be an
« Reply #23 on: December 19, 2013, 10:50:15 AM »
I've used this with great success
CB550 K0
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #24 on: December 19, 2013, 10:54:25 AM »
That's a great tool if you just need to replace the seals, where did you get it?
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
