Author Topic: NOTHING can remove my brake piston  (Read 7269 times)
Offline MoMo
  • Ride like you're invisible
Re: NOTHING can remove my brake piston
« Reply #25 on: December 11, 2010, 08:19:07 PM »
I've seen all sorts of brake problems but never that.  Looks like maybe the PO "rebuilt" it and did not get the clip in the groove.   I had to buy a piston for a customer's  750f, damn thing cost $70.  Hope it cleans up for you...Larry
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #26 on: December 11, 2010, 08:31:26 PM »
Thanks dude for wishing me luck, those pistons/rebuild kits are surprisingly expensive, ran into this with another bike, a kz1000, high price point for what reason, maybe they have to be highly-precision machined to fit in the m/c bore, or maybe its a high-failure-rate item that yields them a nice revenue stream.    The kz1000 also had a stuck m/c piston like this cb900c.
Getting the hard-stuck master cylinder piston out of the m/c bore of the kz1000, well that took me a bit of fumbling around on the kz, I came up with this approach for that bike which I'll use on the 900c -- the old 'tap-as-m/c-piston-puller' trick:
