Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
file/sand the damage out. new bearing in the freezer and heat the steering head thoroughly w/a blow dryer. place bearing squarely, tap on the outer race only. use huge socket if you have one, or otherwise make sure it's square until fully seated.
Great Thanks guys-- the seat in the lower steering head cleaned up nicely. The sanding bit smoothed it out nice and proper. Any advice on removing the lower bearing ring from around the stem on the lower triple? I've cut it 3/4 of the way through with the dremel wheel but am weary of cutting into the triple itself. I've whacked it with a chisel and it hasn't popped through yet. I'm thinking once I cut it through, I'll be able to beat it off with a punch.
