Author Topic: Are 500 and 550 wheel bearings the same?  (Read 1789 times)
Offline Scott S
« on: December 17, 2010, 08:38:35 AM »
 I'm having a heck of a time finding a shop that has All Balls steering stem bearings AND front wheel bearings for my CB500. I can find one or the other, but not both.
 Dennis Kirk says they have them for the 550K. I used the Motogrid site to cross reference and got more than 17 pages of matches.
 What part #'s or bearing size should I ask for when ordering wheel bearings? Anyone know of a place to get steering stem AND wheel bearings?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: Are 500 and 550 wheel bearings the same?
« Reply #1 on: December 17, 2010, 08:44:41 AM »
 And to clarify: I want the All Balls tapered steering stem bearings. I don't care what brand the wheel bearings are.
 Also, will I need to order rubber dust seals for the front as well?
'71 CB500 K0
'81 Yamaha XS650
Offline turboguzzi
« Reply #2 on: December 17, 2010, 09:22:32 AM »
go with 2RS sealed bearings and you can skip the seals
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: December 17, 2010, 10:46:24 AM »
99% sure they are the same.  I used to have a 500 & a 550 and when I changed out the bearings, they were the same.
Offline Scott S
« Reply #4 on: December 17, 2010, 12:25:50 PM »
 Check out this ebay auction. He has the All Balls brand wheel bearings with seals. This auction is for the All Balls steering stem bearings. It lists CB500 in the title, but not in the long list of bike in the description.
  Are these the bearings I need? I asked a question and their reply was " They only fit bikes listed". I pointed out that the CB500 was in the title but not the list and there are three different CB500's (K models, twins, and the '80's models).
 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400174991836&viewitem=&sspagename=STRK%3AMEWAX%3AIT
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #5 on: December 17, 2010, 01:10:30 PM »
 Even Z1's list is confusing. Under '71 CB500, they list the 6302-2RS wheel bearing, but when you look at the detailed list, the '71 CB500 isn't in there!
 They also list a kit with seals, but again, in the detailed listing the '71-73 CB500 isn't included.
 I'm so confused.
'71 CB500 K0
'81 Yamaha XS650
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: December 17, 2010, 02:55:12 PM »
For the wheel bearings, check your parts fiche.  You'll find a 4-digit number with maybe a couple of letters inside some parenthesis.  Take that 4-digit number, chop off the letters, add the 2RS as Turbo said and go to your local bearing supplier (I use Fastenal).
example: SKU: 96140-63020-10 BEARING, RADIAL BALL (6302U)
becomes 6302-2RS.
You can prolly get these bearings for around 5 bux a pop.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Scott S
« Reply #7 on: December 17, 2010, 03:19:25 PM »
 And will I need the rubber dust shields or not?
'71 CB500 K0
'81 Yamaha XS650
« Reply #8 on: December 17, 2010, 03:30:24 PM »
The first time I changed bearings, I ordered up new rubber bits and a new retainer ring.  Glad I did cuz I bugger'd 'em all pretty badly.  Now that I've done it a few times, I can generally salvage it all.  If you need the bike right away, go ahead and order these bits.  If you can afford to be down a few days, wait til you know if you need 'em.
Here is a GREAT tutorial on how to do the job, including building some of the special tools you may need...
http://www.goldwingdocs.com/forum/viewtopic.php?f=11&t=69&sid=d10df75fd3f1bcaaf7161dec65412ea6
Sure.
Is it hard?
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #9 on: December 18, 2010, 07:24:04 PM »
Z1 is definitely a bit confusing. But if you call, they Will walk you through it in a minute. Just ordered last week.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Gaither
  • '77 CB550F
« Reply #10 on: December 19, 2010, 01:38:31 PM »
FWIW
A well-stocked bearing specialty supplier will usualy (maybe not every time) have any bearing you need (ball or roller). Just take the complete old bearing with you. It is amazing what they can lay on the counter for you.
In many cases, it'll also cost less. Quick, easy and no shipping cost - but, you'll likely have to pay sales tax.
Gaither ('77 CB550F)
