Author Topic: CB400F Intake Manifolds  (Read 1966 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
« on: December 18, 2010, 10:08:06 AM »
I'm looking to use CB400F intake manifolds with a custom adapter to mount soem Keihin CR26 carbs to me CB550F.
It seems that there are inside and outside manifolds for the CB400F and I was wondering what the difference between them is. Can someone post pistures of their manfolds for me. A side photo showing any angle to the manifolds would be very helpful too.
I was just looking for the CB440F parts manual and found that the file has been deleted on the download server.
If someone hase a copy of new link to download the parts manual, please post it here.
Thanks
« Last Edit: December 21, 2010, 10:19:16 PM by FunJimmy »
Offline MoMo
  • Ride like you're invisible
Re: CB400F Parts Manual & Intake Manifolds
« Reply #1 on: December 18, 2010, 01:26:44 PM »
try this link, it may have what you are looking for.  http://www.mrcycles.com/fiche_section_detail.asp    ....Larry
  • Be careful you might get a
« Reply #2 on: December 18, 2010, 11:23:43 PM »
There's some good photos on David Silver's website.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: December 21, 2010, 05:13:51 PM »
Been away with the family and just checked in.
I'll check those suggestions out.
Thanks Guys
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: CB400F Intake Manifolds
« Reply #4 on: December 21, 2010, 10:18:15 PM »
OK
I found the pictures of both the inside two and outer two manifolds but can't see any difference at all.
Can someone measure the inside bore and post it here?
Thanks
jimmy
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #5 on: December 21, 2010, 10:30:51 PM »
Inside bore on motor side is around 23mm.
The manifolds are marked 1-4 and 2-3. 1 and 4 have the same angle and 2 and 3 the same angle.
number 1 fits with the 1 showing, and number 4 fits with the 4 showing, basically upside down to number one. same applies to 2 and 3 manifolds.
If you bore them out larger, you might loose the O-ring groove. I have gaskets to fit if you need them.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #6 on: December 22, 2010, 04:20:15 PM »
Kevin
Thanks for the specifications Kevin.
I need to open those up to 26mm so I had better consider something else.
Much appreciated.
Jim
« Reply #7 on: December 22, 2010, 04:56:36 PM »
I've got a 400F apart at the moment and you can have those manifolds to experiment if it helps.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #8 on: December 22, 2010, 05:11:13 PM »
Thanks Brent
I'm gonna hack around the garage later tonight and see what gives.
Will let you know if I need to borrow them though.
Could you tell me what thread diameter the CB440F uses on the throttle cables at the grip?
Cheers
« Last Edit: December 22, 2010, 05:13:19 PM by FunJimmy »
« Reply #9 on: December 22, 2010, 08:03:52 PM »
Same as your 550
Offline ttr400
« Reply #10 on: December 22, 2010, 08:54:53 PM »
You can open up the 400F manifolds to 26mm. will have to use gaskets instead of the O-rings to seal.
Kevin
www.ttr400.com
Offline ttr400
« Reply #11 on: December 22, 2010, 08:56:36 PM »
Forgot to mention.
I use the VFR/RVF400 throttle housing with my CR's. used with the stock 400f cables.
Kevin
www.ttr400.com
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #12 on: December 22, 2010, 09:07:18 PM »
Kevin
Kevin
Maybe the CB400F manifolds are the way to go then.
If I where to make a flat plate adapter to mount the to would I need both types or would either do?
I guess I'll need 400 cables too.
Thanks for all ther help guys
Offline faux fiddy
  • bike in a box
« Reply #13 on: December 23, 2010, 03:30:48 AM »
Here's something I stumbled upon- a clearance sale to boot!  Several sizes.
http://www.bikebandit.com/mikuni-mounting-flange
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
