Author Topic: More GS 1100 questions.......  (Read 4566 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« on: December 18, 2010, 02:47:26 PM »
Can't find my old thread ???
Here's the question.
Does anyone know the stock exhaust numbers for a 82/GS-1100E or a link I could look at?
The reason I'm not asking here....  http://www.thegsresources.com/_forum/  is that if I ask, I may loose a good lead on a stock system on Craig's ;)
Offline ev0lve
Re: More GS 1100 questions.......
« Reply #1 on: December 18, 2010, 05:05:35 PM »
It's not on cmsnl?
http://www.cmsnl.com/suzuki-gs1100-ees-1982-1983-usa_model15996/partslist/95966.html
PIPE,EXHAUST CE
Make: Suzuki
OEM#: 14100-49303-H01
They list a model Z that I'm not familiar with. Looks like 4 baffles? Hmmm, there's a part 14 in th pic but no listing in the for a part 14 in the list.
« Last Edit: December 18, 2010, 05:12:03 PM by Iggy »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #2 on: December 18, 2010, 07:23:47 PM »
Here is the info given by the seller.
The numbers on the mufflers are: Sankei 2200
SUZ 2GE1150
I'm lost.
Offline ev0lve
« Reply #3 on: December 18, 2010, 07:31:13 PM »
Aren't the 1150's later in the series? Post 83? Mine was an 82 with an 1150 motor in it but it had a Yosh so I never saw the stock pipes.
I don't think anything but the displacement changed on the engines so they'd probably just fit up but you're getting outside my (admittedly tiny) knowledge.
« Last Edit: December 18, 2010, 07:39:58 PM by Iggy »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #4 on: December 18, 2010, 07:44:37 PM »
Here it is. http://portland.craigslist.org/clk/mcy/2115762284.html
I'm considering just buying it. I have talked to him, might just be worth the gamble. He says they are (as new) ???
Offline pdxPope
  • Hit Shit, Hat Shat, Hut Shut,
« Reply #5 on: December 18, 2010, 08:11:48 PM »
Those sure look like the ones on my bike ('83GS1100E).
Mine are stamped on each muffler: DGM36893S
                                                GS110X
Nothing on the headpipes (although I didn't take them off the bike to check).
-JP
The flowers say "Let's go shopping together..."
While the unicorn whispers "...for adult toys."
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #6 on: December 18, 2010, 09:47:51 PM »
If you have the 1982 GS1100E, that had a 'z' designator to indicate the 1982 model year.
I own a 1981 GS1100E, and it has 'x' designator for the '81 model year, so in a parts lookup I ignore all the different models and only pay attention to GS1100Ex.   You would do the same except for GS1100Ez.  Now, if you have a GS1100GL, that's a different bike (I think the GL was the 'cruiser' model...)
I just did a parts lookup on my Zedder cross-reference.  The right muffler has part number:
14301-49201.   Now, that's hard to compare to your Sankei number that is stamped on the muffler your seller gave you -- for whatever reason, the Sankei number (I think Suzuki sourced the mufflers from this 'Sankei' company as did other Jap manufacturers) the Sankei number on the muffler rarely seems to match the factory part number.  Not sure why.
However, here's the important bit.  My parts cross reference always shows the number of Suzuki models that use that same part (it is, after all, a 'cross reference').  Only one bike uses the 1982 GS1100Ez muffler -- that being the bike itself.  No other Suzuki models (apparently) use the same muffler as the 1982 GS1100Ez.
Now that doesn't mean the 1150 system (the 1150 leads me to believe it's from a GS1150) you're thinking about buying won't fit, it is a gamble.  The style used on parts look similar on different models during a span of years -- like the 4-into-4 stock pipes on cb750s were shared across many years, the HM300s then the HM341s.  The *styling* of the part, the outward appearance, looks similar but the part can be different.  Will it fit?  I always ask myself "if it doesn't fit can I resell it for the same money."
As you probably know, for 1982 Suzuki made several 1100 models:
GS1100Ez
GS1100GKz
GS1100GLz
The 1150 bikes didn't come out in the U.S. until 1985 I believe.
I don't know what the demand is for an 1150 stock exhaust system, but if it's cheap enough and can afford to wait a bit if you have to sell it due to not fitting, it's probably worth the risk.
I check my Zedder cross-reference for the following part number given above:
PIPE,EXHAUST CE
Make: Suzuki
This is the center header pipe pair (hence the 'CE' designation I suspect), the 2 center pipes on the 1100, for the 1983 GS1100E.   The 2 outside header pipes are fixed to the mufflers.  The 2 inside header pipes are connected together and not fixed to the muffler section unlike the outside pipes -- maybe to make the system easier to install/manufacturing tolerances?  Not sure.
Here is a parts diagram for my 1981 GS1100Ex stock system:
« Last Edit: December 18, 2010, 10:11:28 PM by Hondawggie »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #8 on: December 19, 2010, 09:22:17 AM »
Here is an additional photo of the header pipes.
2 have 2 end flanges, 2 only have 1 flange? The system I removed all ends are the same.
Offline medic09
« Reply #9 on: December 19, 2010, 11:24:51 AM »
Didn't Terry in Australia have experience with this bike?  Or am I thinking of something only similar?
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
« Reply #10 on: December 19, 2010, 02:23:36 PM »
Terry has the earlier GS1000,they are a different animal all together, different engine and no anti dive suspension.....
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #11 on: August 26, 2021, 03:32:38 PM »
Another gs1100e project.
Question. Re installing front wheel and brakes after tear down. I never removed the forks. Tightening up the axel bolt with both brakes drained and loose. Can't tighten up axel nut without binding? Wondering if forks might be twisted? Never rode this bike.
« Reply #12 on: August 26, 2021, 10:11:30 PM »
Easy way to tell.  Block up the bike get weight off the wheel, then slide a block under wheel , dont force it.
 May have to rie handle bars .
 Loosen one fork leg on axle ., then loosen THAT TUBE  in triple clamps., THEN ROTATE the forktube.
 Watch the fork against the hub, ic it starts moving, then goes in or out as you turn fork.. it IS BENT.. ..
 Where are you now, I found my fork tube blocks.. may be able to straighten them.. what size are they ?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #13 on: August 27, 2021, 04:27:49 PM »
Hey. I'm still in Kelowna.
« Reply #14 on: August 28, 2021, 10:15:26 AM »
You guys are neighbors then...
« Reply #15 on: August 28, 2021, 01:30:50 PM »
Have bern for a while I think, used to see him when i was downtown everyday, but that ended 2016.
 Yeah so I did not know if he was still here..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #16 on: August 29, 2021, 10:46:01 AM »
No idea what size they are. Stock anyway. I'm up in Rutland.
« Reply #17 on: August 30, 2021, 12:19:59 PM »
They are 37mm , let me know if you need them straightened..
