Author Topic: cb 500 rear brake pedal spidle  (Read 1361 times)
Offline bogornd
« on: December 18, 2010, 05:21:31 PM »
well i hope thats what it's called.
So i have a b 500 frame 1973 which i#m trying to get stripped for powder coating.
the spindle with splines that the brake pedal ataches to will not come out.
it pushes through till only the outer set of splines are showing then it feels like its hitting something.
any ideas appreciated before i resort to brute force.
thanks Andre
Offline MoMo
  • Ride like you're invisible
Re: cb 500 rear brake pedal spidle
« Reply #1 on: December 18, 2010, 05:26:37 PM »
Is the swing arm off? Sometimes the return spring can cause it to jam. Picture would help...Larry
« Reply #2 on: December 18, 2010, 06:02:12 PM »
Remove the swingarm, then the brake shaft.  ;)
Offline eideteker
« Reply #3 on: December 18, 2010, 06:16:20 PM »
I got mine off without removing the swingarm, is that normal?  ;D
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
« Reply #4 on: December 18, 2010, 09:33:05 PM »
It can be done, but if you're going to paint the frame....  ::)
