Author Topic: Oil!!!!...in there???? HELP!  (Read 2500 times)
Offline Jaydem
« on: December 23, 2010, 05:27:23 PM »
So I was playing around with my bike today (inspecting)
I decided to take the "dynamo" or i think also referred to as the "stator" cover off and a bunch of OIL came out of there????
Question.....is there supposed to be oil in the alternator area????
THanks
1974 Honda CB 750 (Restoration/Cafe Project)
Offline MoMo
  • Ride like you're invisible
Re: Oil!!!!...in there???? HELP!
« Reply #1 on: December 23, 2010, 05:40:06 PM »
Model of bike?  With many Hondas that is normal...Larry
Offline Jaydem
« Reply #2 on: December 23, 2010, 05:41:31 PM »
its a honda cb 750 1974
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #3 on: December 23, 2010, 05:50:33 PM »
yep.  normal for small amount of oil...mebbe 1/2 oz to an ounce mebbe.
MATT
Offline Jaydem
« Reply #4 on: December 23, 2010, 05:53:44 PM »
Yeah, I had alot more than that!
Offline going4speed
« Reply #5 on: December 23, 2010, 06:00:26 PM »
Yea I had a TON more than that on my 1975 CB750k.  I'm calling it normal.
Offline Jaydem
« Reply #6 on: December 23, 2010, 06:02:53 PM »
ok i am feeling alittle better, Im not the only one...
I have about 1 qt come out :o
KingCustomCycles.com
« Reply #7 on: December 24, 2010, 03:27:05 AM »
If it hasn't run in awhile, then the scavenge oil pump has not drained the oil in the engine case back up to the tank.  It will drain after a bit of running and return to normal.  I drained a gallon of gasoline out of mine yesterday.  Now THAT is abnormal.  :)
Offline Jaydem
« Reply #8 on: December 24, 2010, 06:23:16 AM »
Seems like the consenses is that oil SHOULD be in there for lubrication. The bike hasnt been ran in about 10 years. Trying to get her back to life.
Thanks for all the input!
Offline Johnie
« Reply #9 on: December 24, 2010, 06:24:02 AM »
If you decide to take the stator cover off again lean the bike to the right side with a small block under the center stand. That will allow you to work in the area without oil running out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
