Author Topic: 74 cb750 carborator problems  (Read 1533 times)
Offline 74cb750
« on: April 29, 2005, 02:20:03 PM »
Hello. Yes, before you ask I just did spend a great deal of time looking at the former posts in the carb section. My carbs were just rebuilt. Tank is clean and filled with gas, new lines/filters without air. The problem: the center carborators are empty. No fuel at all. Any ideas.?
Laugh at least once a day.
Life  $ucks, then you die.
Offline kghost
Re: 74 cb750 carborator problems
« Reply #1 on: April 29, 2005, 02:30:46 PM »
If its like a 72/73 then one fuel line feeds 1+2 and one fuel line feeds 3+4. There are two pipes that connect the fuel lines to the carbs. (makes a "T"). Assuming its assembled correctly. If 1 and 4 are recieving fuel then 2 and 3 should as well.
This leads me to believe you have to have a problem with float needles or float height. If fuel is getting to the outboard carbs as above.
You may have assembled the floats in 2+3 and got them stuck in the up position, cutting off the fuel to them. Didn't put'em in upside down did you?
Stranger in a strange land
Offline 74cb750
« Reply #2 on: April 29, 2005, 05:18:51 PM »
I pulled the bowls off 2 & 3, they are bone dry.  :-\ It was such a pain in the a$$ to get these back on the bike....would it be the "T" connector is plugged. I could have sworn I blew it out before I assembled these 4 years ago.
Offline 74cb750
« Reply #3 on: May 07, 2005, 12:20:05 PM »
The float needles were stuck
