Author Topic: Small Brake issue  (Read 930 times)
Offline Kouros
    • DOUBLESTRIPES.COM
Small Brake issue
« on: December 28, 2010, 02:47:03 PM »
on a 750 K4 brake and a few questions, the taller brake pad is not fitting right and dropping in the indentation inside the Caliper! Any remedies?
Also, can you explain what the screw is for on the pad?
And is Dot3 fluid used for cars okay?
Can't see the o-ring
-K
« Last Edit: December 28, 2010, 04:11:58 PM by Kouros »
1974 CB750 K4 (Re-build in-progress)
Offline Kouros
    • DOUBLESTRIPES.COM
Re: Small Brake issue
« Reply #1 on: December 28, 2010, 03:59:31 PM »
I guess the o-ring is behind the cylinder. But mine is frozen solid such that it does not come out with hand. Any suggestions there?
Offline fmctm1sw
« Reply #2 on: December 28, 2010, 04:02:35 PM »
afaik there should be a caliper seal in there.  You're saying the piston is froze in there?  Some guys here have recommended a grease gun or air pressure...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Kouros
    • DOUBLESTRIPES.COM
« Reply #3 on: December 28, 2010, 04:22:49 PM »
Lol...It out.
Covered one hole with my thumb. Put the air compressor blower tip inside the other. POP ;)
Just that no one told me to not point it at my neighbors car. ;D
Off to polishing
Alright so the other questions about:
Pad not fitting right
What the screw on top of the pad is for and
Is DOT3 for cars okay
Thanks
Offline fmctm1sw
« Reply #4 on: December 28, 2010, 04:33:58 PM »
here's a typical caliper.  It may help you see where the stuff goes...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fasturd
« Reply #5 on: December 28, 2010, 04:59:27 PM »
A picture of the pad might help. The screw may be a locator to keep the pad from turning.
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline Kouros
    • DOUBLESTRIPES.COM
« Reply #6 on: December 28, 2010, 05:05:03 PM »
Camera with no battery. But now that you mention it, yes it might be a locator.
Thanks fm
-K
« Last Edit: December 28, 2010, 05:24:41 PM by Kouros »
Offline Toxic
« Reply #7 on: December 28, 2010, 05:51:55 PM »
Yes it is a locating pin.
Dot 3 for cars is fine
« Reply #8 on: December 28, 2010, 08:47:30 PM »
I have had new pads that the braking material was manufactured a little to big and the outside edges needed to be sanded down/grinded a little bit to get the correct fitment.
