Author Topic: UNIVERSAL Carburetor  (Read 3086 times)
geosvald
« on: March 21, 2006, 01:30:21 PM »
Has anyone ever used any carbs other than the originals? Anyone seen a kit that would allow you to set up the spread of the carbs to match whatever engine is being used? By the way my project is a 1978 CB550K.
Offline kaceyf2
Re: UNIVERSAL Carburetor
« Reply #1 on: March 21, 2006, 01:38:34 PM »
seen a 2 and a half inch Su off a land rover on a home made inlet tract, that worked well, I have the specs in a magazine, I kept it just for an occasion like this!
hope that helps a little, people have fitted mikuni smoothbores as well with no probs, after initial set up. And i am sure plenty of others.
In my own experience...
It wasn't a Previous Owner who didnt know what he was doing that messed up your bike, it was The Previous owners mate who THOUGHT that HE did.
Offline dusterdude
« Reply #2 on: March 21, 2006, 01:51:16 PM »
kacey,how bout the specs or pics
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline mrbreeze
  • Not your average
« Reply #3 on: March 21, 2006, 11:43:13 PM »
Wouldn't it be cool to have single 4 barrel carb like a Q jet on a Chevy? Spread bore.....big ass secondaries...give it the onion and take off like you just hit the nitrous? Yeah....I know....it's a dream but hey!!...It's my dream and besides....who cares for taking that rack down everytime you need to clean or adjust?
MEMBER # 257
geosvald
« Reply #4 on: March 22, 2006, 04:08:43 AM »
I have seen a set of carbs that look like you can set it up to match the manifold and probably drill your own holes for the butterflies and the throttle shafts. Then I guess  you'd have to make your own fuel pipes. Of course I'd be ok with that too if it could be done for less than an arm and that ...yeah.
Offline cb(r)
« Reply #5 on: March 22, 2006, 05:49:46 AM »
here is a dual carb set up for a 750.  I have heard of a single 4 barrel carb set up but have never actually seen one for the cb.
http://www.cyclexchange.net/Carb%20System%20Comp%20Page.htm
hopefully the site shows up
Offline dusterdude
« Reply #6 on: March 22, 2006, 05:57:45 AM »
that cycle exchange deal looks pretty good,but a single setup would be the bees knees.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
mylittleho
« Reply #7 on: March 22, 2006, 07:18:47 AM »
How about this.. a single barrel weber carb.. I had one of these bad boys on my old 2.0L Mitsubishi pickup
Don't know how you would adapt it to the motorcycle though.. How would you make sure all cylinders got fed properly?
http://cgi.ebay.com/ebaymotors/Weber-Carb-Kit-Mighty-Max-Montero-Dodge-D50-Truck-B2600_W0QQcmdZViewItemQQcategoryZ33550QQitemZ8049369185QQrdZ1QQsspagenameZWDVW
also how will a automotive carb deal with the turns of a motorcycle?
I'd love to see some VW weber carbs retrofitted.. that would be the #$%*..
amattel
« Reply #8 on: March 22, 2006, 07:51:11 PM »
Kelvin8
« Reply #9 on: March 23, 2006, 01:00:56 AM »
Twin side draft Webers would be nice. Equal length intake runners, plenum onto which the carbs are mounted.
Offline byidesign
« Reply #10 on: March 23, 2006, 06:15:04 AM »
On other than originals,I made a set of aluminum offset adaptors, so you could put the
   older 77-78{pre CV } carbs onto the later 1980 and up heads on CB650's--CB750's
      {intake spread is different} so they could be slid on using the 1980and up
         rubber boots, and as the pre CV carbs are shorter, could still use an airbox.
        off the older model bike to match the carb intake.
     the   bike{ cb750c,  } still running great 3 yrs later ,he just didn't like Cv carbs,
             and didn't want to play with the heads.
                     Bruce
82CB650SC,80CM400
Offline Jay B
« Reply #11 on: March 23, 2006, 08:51:00 AM »
S&S Super E carbs (one or two) would work great for this if you could get a manifold figured out. I had one on an old Shovelhead, they are very simple, easy to tune. They have an adjustable accel pump. It was a huge improvement over the Keihin that was on there.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: March 23, 2006, 08:53:48 AM »
Ah, music to my ears,  ;D
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #13 on: March 23, 2006, 09:04:31 AM »
That thing is really sexy. It begs the question though, if one were to fabricate the manifolds, you could use any appropriate carbs in dual configuration, right?
/edit It appears those carbs are 110-120ish USD, so with the pre-jetting, the manifolds, the throttle cable, and the velocity stacks (not to mention the pretesting and fabrication stuff) already done, 500 bucks ain't so bad.
« Last Edit: March 23, 2006, 09:10:10 AM by mlinder »
No.
Offline dusterdude
« Reply #14 on: March 23, 2006, 11:20:32 AM »
jay,agreed,the super e is an excellent carb,i have on the pan.mlinder,the dual mikunis are a good deal too
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
geosvald
« Reply #15 on: March 23, 2006, 01:49:43 PM »
If you make your own manifolds, i guess they don't have to be straight. Think about a big V8 they have to put some bends in to make all the tubes equal length if it only uses one carb. If you have good atomization and good flow, maybe downdrafts would work. :-\
Stevearino
« Reply #16 on: March 23, 2006, 02:19:26 PM »
Hell, why stop there.  I once saw pictures of a blown GL1100!  It was referred to as a pavement wrinkler.
