Author Topic: Fork Oil leak...special washer?  (Read 1918 times)
Offline Scott S
« on: December 29, 2010, 12:59:50 PM »
 '71 CB500.
 I have all the stuff to do fork seals, wheel bearings and steering bearings this Winter. I've noticed a leak from the bottom of the left fork. Looking at the parts fiche, it shows a "special washer" under the socket bolt on the bottom of the fork.
 SKU: 90544-283-000
WASHER, SPECIAL (8MM)
 What's so "special" about this washer? Is it something I'll be able to find/replace?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Toxic
Re: Fork Oil leak...special washer?
« Reply #1 on: December 29, 2010, 01:04:15 PM »
Curious as well.
I used a rubber "o" ring and it seems to be working better than the copper one I tried.
« Reply #2 on: December 29, 2010, 01:09:16 PM »
It's copper. It's "special" in that it keeps the oil from coming out.   ;D  It will give like a crush washer and seal it up.
I don't think you could get the proper amount of torque back on that bolt with a rubber ORing under it, you'd destroy the Oring.
Offline Scott S
« Reply #3 on: December 29, 2010, 01:33:52 PM »
 Copper, eh? Cool...I have an assortment of copper washers. Shouldn't be a problem, then.
'71 CB500 K0
'81 Yamaha XS650
« Reply #4 on: December 29, 2010, 04:51:53 PM »
They may be special in dimension also. IIRC, they need to fit tight around the bolt, 8mm,  and not have an oversize OD as it fits down in a pocket.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: December 29, 2010, 07:20:45 PM »
Just buy the damn honda part, it doesn't cost that much and I'll guarantee you it won't leak for another 20 years or more.
