Author Topic: older chevy guys  (Read 2129 times)
older chevy guys
« on: December 29, 2010, 11:34:57 PM »
any small block gurus here?can a 307 block,with 307 pistons, use a 350 crank with 400 rods?,the 400 rods are shorter,i know the 307/327/350 block are more or less the same,the 350 crank would cause the pistons to hit the head with the stock rods and 307 pistons,but with the 400 rods i think its ok??so a bored to 4 inch 307,with a 350 crank and 400 rods will work,itll be a 350 cid then,with a 307 engine number.
Offline mark
Re: older chevy guys
« Reply #1 on: December 29, 2010, 11:47:37 PM »
...a bored to 4 inch 307,...
don't know about the crank/rods part but I'm pretty sure a 307 block doesn't have enough iron to handle a 1/8" overbore.
F you mark...... F you.
Offline fastbroshi
  • Puppet
« Reply #2 on: December 30, 2010, 12:17:39 AM »
I wouldn't call myself a guru, but I believe the 307 is a totally different animal compared to the 305, which is basically just a destroked 350.
Just call me Timmaaaaay!!!
« Reply #3 on: December 30, 2010, 02:31:11 AM »
the 305 will not compute here thanks fastbroshi,the 305 will have crank clearance and bore  issues,the 307 will go four inches ok,its the plus .20 they might not handle,for example a 327 block(four inch) will go the plus .20 from the stock four inch,its the compression height once the longer stroke(3.48)350 crank is used,the 307 stroke is 3.25,will the shorter 400 rods work?i used to have an old book,"how to hot rod small block chevs"and im sure thats the combo,i still have some old "smoky yunicks"books,but the parts swapping isnt covered.
Offline fastbroshi
  • Puppet
« Reply #4 on: December 30, 2010, 03:06:39 AM »
Maybe I had that backwards, maybe the 305 is the different animal?  I have a Chevy engine building book, will see if I can find it this evening.
« Reply #5 on: December 30, 2010, 03:11:35 AM »
thanks broshi,the 305 is one of those"dont worry about souping it up"engines.
Offline fastbroshi
  • Puppet
« Reply #6 on: December 30, 2010, 03:24:27 AM »
That's right, my friend had a '77 Nova with that motor, so I started reading a bit to see what we could do.  Besides a different carb or exhaust tweaks, it would be hard compared to a 350 for sure.
Offline wardenerd
  • '77 550F '81 650C
« Reply #7 on: December 30, 2010, 03:58:03 AM »
buy a ford
« Reply #8 on: December 30, 2010, 04:12:14 AM »
MODERATORS!!KILL WARDENERD!i like the windsor engine,even though the clevo has better valve gear and bearings,and oil supply,i built a 351 windsor about 94 for a mate,as a tow motor,man it went well,same towing as if unloaded,the cam was a sig erson tq20 hydraulic,just a holley 600 on a performer,this thing was a heavy car,an xy fairmont station wagon,it span the wheels easy,i like fords,towing two bikes we easily out traffic light dragged a smokey xbgt,im guessing a 302 clevo up a steep hill.
i wasnt there but some mates tricked greg by saying hed been seen doing burnouts and had to clean them off the road,after he tried to clean them up they told him the truth,wish i was there for that one,the white wagon is a 302 fairmont.ignore the lower photo,thats how i received the scanned email,this is about,a long time ago.
« Last Edit: December 30, 2010, 04:22:38 AM by dave500 »
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #9 on: December 30, 2010, 03:12:08 PM »
A 307 is a 283 block with a 327 crank, and a 302 is a 327 block with a 283 crank. a 305 is POS >:(
Fonda Honda
Offline Skunk Stripe
« Reply #10 on: December 30, 2010, 03:22:05 PM »
The 305 sucked bad but the 302 was excellent!
Offline 333
  • Time for change
« Reply #11 on: December 30, 2010, 03:30:44 PM »
Can someone please run that Ford guy out of here?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #12 on: December 30, 2010, 03:31:37 PM »
Well IF you are referring to me, then you must not know about the chevy 302!
Offline mark
« Reply #13 on: December 30, 2010, 04:18:59 PM »
....the 305 is one of those"dont worry about souping it up"engines.
funny, I always put the 307 in that category too.
« Reply #14 on: December 30, 2010, 09:58:27 PM »
My 84 Z28 had a 305 with 150hp. Som#$%* couldn't burn the tires. Get rid of it!
Offline 333
  • Time for change
« Reply #15 on: December 30, 2010, 09:58:55 PM »
No, I'm talkin' about this guy;
buy a ford
« Reply #16 on: December 30, 2010, 11:11:59 PM »
the 307 is a great engine,it only needs a four barrel to open it up,they all came with a two.
