This is a key statement "The trick development here is to try to provide multi-spark capability without adding several amps to the bike's load: then there will be a net performance improvement. In such achievement lies a patent right. "
Also add in that this is wasted spark, so Ken is popping off say 3 sparks at 9000rpm, asking alot to get that coil fully charged in wasted spark config in my opinion.
9000 rpm is his default rev limiter setting btw, on the advertised non user programable version, which they can change, at an additional cost, but you cannot, should you like this freedom, you will need to pay 80.00 more I believe it was, plus 120.00 I think it was for the cable and software.
Most stock 750's can run more than 9000, let alone a hopped up version.
this can be referenced here
http://cyclex.yuku.com/topic/209/power-arc-curvesI ended up going with the dyna 2000 and their new compact coils and wires for right at 409.00, it is user programable should I choose, the cable only cost 100.00, there are a ton of features and settings.
JMHO
