Author Topic: If I use a CB750 rim?...  (Read 767 times)
Offline q2418130103p
« on: January 02, 2011, 11:24:36 AM »
If I used a 2.15" rear rim from a cb750 on my '74 cb550, will the spoke lengths be the same as the standard cb550 rim's spokes would be?
« Last Edit: January 02, 2011, 11:29:00 AM by q2418130103p »
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline Kevin400F
Re: If I use a CB750 rim?...
« Reply #1 on: January 02, 2011, 11:33:43 AM »
Yep.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: January 02, 2011, 11:34:00 AM »
Since the spokes connect to the rim at it's center, it would be the rim's diameter that would determine the spoke length.  I'm pretty sure both hubs use a 4x10 (40 spoke) pattern, so that shouldn't be an issue.
What I would worry about is interference with the rear brake stay if you are putting it on the rear.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #3 on: January 02, 2011, 11:41:31 AM »
Thanks guys.
I was planning on making a nice looking brake stay arm anyway, but I am only putting a 120 on.
