long story short. aquired a 78 cb750k a few months ago from my uncle. was non running for about 20 years. engine seized. bought new engine that turned over and had compression and did an engine swap. that engine was also not run in a long while. list of stuff I have done:
Changed plugs
checked for spark
adjusted points
adjusted timing
checked electric starter
changed oil
new battery
changed all fuses
new fuel in clean gas tank
had carbs cleaned/ rebuilt by SOHCDigger
new throttle cable
so....going to start the bike in the first time in forever. Choke on, petcock on, tried electric starter, turns over....won't start. just turns over. petcock is not clogged. how can i make sure fuel is going to the engine? do i really need to prime the accelerator pump, and how do i do that. what the heck could i be missing? remove the gremlins?
I've just about given up.
HELLLLLLLP!
![Cry :'(](http://forums.sohc4.net/Smileys/default/cry.gif)
