Author Topic: 750's engine case screw sizes -- listed--  (Read 824 times)
Offline strawhouse
« on: January 03, 2011, 02:53:42 PM »
Has anyone documented the philips screw sizes for the engine case on a 750?  I reallize that there are many places to purchase complete engine screw kits.  I could measure each bolt but I thought someone must have done this already and made it available.
« Last Edit: January 05, 2011, 04:52:31 AM by strawhouse »
Pacifist with a gun
Offline strawhouse
Re: 750's engine case screw sizes
« Reply #1 on: January 03, 2011, 05:26:31 PM »
Just figured out that they are M6 X 1.0, the bolt that holds the speedo into the head is M5 X 0.8 X 25mm.  I just picked up a bunch of allen head stainless bolts, I will post the results tomorrow with the measurements.
« Last Edit: January 04, 2011, 02:27:54 PM by strawhouse »
Pacifist with a gun
Offline strawhouse
« Reply #2 on: January 04, 2011, 02:30:15 PM »
Started to get the hardware installed on the engine, so far so good.  The stainless bolts look pretty sweet on the black engine!
Pacifist with a gun
Offline gnarlycharlie4u
  • Far from being an
« Reply #3 on: January 04, 2011, 02:35:19 PM »
bump this. I'm interested in all the sizes so I could build my own allen head kit without having to actually bust out a measuring tape or look real hard at a diagram.
haha
Offline markb
  • When I finish my current project I might be a
« Reply #4 on: January 04, 2011, 03:55:17 PM »
Here's (part of) a spreadsheet I use to check my "inventory" when I replate/replace fasteners on my sandcasts.  This is only the phillips head screws.  Use it if you can and at your own risk.  It might be slightly different for later 750's.  I hope it helps.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline strawhouse
« Reply #5 on: January 04, 2011, 05:36:16 PM »
So heres my list, its not as fancy as markb's but it works.  It fits my 78 750 F3 but it shows that it will also work on a K3 K4 K5 any other models it may fit but Im not too sure of.  Some of the bolt sizes have been shortened... eg, I wasnt able to buy a 36mm long bolt so I got a 35mm long bolt.  It works for me but I just want people to know this so enjoy at your own risk.
All Bolts listed are M6X1.0 unless otherwise stated, the numbers listed are for length.
Valve Cover ( I did not include the bolts under the top cover )
4- 40mm
1- 50mm
2- 75mm
10- 60mm
Speedo screw M5X.08X25mm
Transmission Cover
2- 30mm
2- 35mm
3- 40mm
2- 50mm
2- 55mm
Generator Cover
3- 20mm
7- 30mm
1- 35mm
Clutch Cover
7- 25mm
3- 35mm
Hope that helps out, as I replace more I will re post.
Pacifist with a gun
