Author Topic: Aghhhh! 750 Brakes!  (Read 1545 times)
Offline DYSKORD
Aghhhh! 750 Brakes!
« on: January 03, 2011, 09:28:30 PM »
There are too many posts to find the fix so here it goes. Pretty straight forward, when removing pad B fron caliper B (cotter pin side), the pad split in half and now the half that is recessed in the caliper is stuck. What should I do? It is soaking pad side down in brake cleaner as we speak. 76 cb750f.
« Last Edit: January 03, 2011, 10:14:38 PM by DYSKORD »
Offline DYSKORD
Re: Aghhhh! Brakes!
« Reply #1 on: January 03, 2011, 09:52:29 PM »
Just to clarify the metal backing of the pad is stuck in the caliper. the braking material seperated and left it behind.
Offline Hush
Re: Aghhhh! Brakes!
« Reply #2 on: January 03, 2011, 09:57:00 PM »
You mean Aghhhhh! 750 Brakes!  ;D sorry if it was a 650 I could help, they are like big square flat things. :D
Offline the technological J
  • deliciouso!
Re: Aghhhh! Brakes!
« Reply #3 on: January 03, 2011, 10:02:31 PM »
have you seperated the calipers(?) and tryed to access the  part that way? i would try to press the  caliper as far back as i could( via somekind of clamp or vise)... just be patient maybe if it loosens just a little you could get it to start to rotate and shake some debris clear and get it out
« Last Edit: January 03, 2011, 10:04:48 PM by the technological J »
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline DYSKORD
Re: Aghhhh! Brakes!
« Reply #4 on: January 03, 2011, 10:13:21 PM »
Calipers and all are diassembled. The problem is on the side of the stationary caliper/pad (wheel side) so there is no moving anything anywhere. The backing of the brake pad is stuck in the caliper.
  • deliciouso!
Re: Aghhhh! 750 Brakes!
« Reply #5 on: January 03, 2011, 10:19:25 PM »
maybe dremel a slot in it and give it some heat and smack it to try to loosen the corrosion on it
94 ST1100..Gone
Online scottly
Re: Aghhhh! Brakes!
« Reply #6 on: January 03, 2011, 10:25:39 PM »
You might try drilling a hole through the steel backing and taping it. Then, threading a bolt into the tapped hole "might" push the backing plate away from the caliper half, or at least give you something to attach an improvised "puller" to. Good luck!
« Reply #7 on: January 03, 2011, 10:30:45 PM »
try and rap the edge to jar the backing plate out,it might have been siliconed in to stop squealing?or a thin blade and try and lever it a little enough to get a small screw driver under it?
Offline DYSKORD
« Reply #8 on: January 03, 2011, 10:47:27 PM »
I have tried chisels and screwdrivers. Only thing left is heat it over the stove I guess.
Offline fastbroshi
  • Puppet
« Reply #9 on: January 03, 2011, 10:58:29 PM »
Must be stuck in their good because I had that happen with a 550 caliper.  That one was cocked in there because someone omitted the little plastic washer spacer thing when reassembling.  Even then it came out.  After walking my bike home on a country two lane with the caliper dragging.  Uphill.  At night.  In Transylvania.
Just call me Timmaaaaay!!!
Online scottly
« Reply #10 on: January 03, 2011, 11:02:21 PM »
LOL! You forgot to mention uphill, both ways!
Offline DYSKORD
« Reply #11 on: January 03, 2011, 11:05:25 PM »
in two feet of snow.
Offline fastbroshi
  • Puppet
« Reply #12 on: January 03, 2011, 11:09:56 PM »
With werewolves chasing me.  That had friggin laser beams on their friggin heads.
Online scottly
« Reply #13 on: January 03, 2011, 11:11:30 PM »
Seriously, you need to apply some sort of force to get the backing out. I would drill/tap, as I already suggested, or weld a bolt to the plate, and then pull against that.
Offline DYSKORD
« Reply #14 on: January 03, 2011, 11:17:09 PM »
Thanks Scotty I will give it a try. Pretty frustrating.
Offline fastbroshi
  • Puppet
« Reply #15 on: January 04, 2011, 12:28:31 AM »
Or failing that, drill a small hole and run an EZOut in there, it should start to dig in a bit and give you something to pull with
Offline Hush
« Reply #16 on: January 04, 2011, 01:00:46 AM »
How about leaving it in the freezer overnight?
Works for other bits of our bikes, the plate is metal and the caliper bit is an alloy isn't it?
Offline DYSKORD
« Reply #17 on: January 04, 2011, 02:21:31 AM »
Gas cook top for 4mins. Popped that sucker rght out.
Thanks guys.
Offline Hush
« Reply #18 on: January 04, 2011, 11:18:20 AM »
There's always and answer.....next please! ;D
