Poll
where is the positive wire for the starter located
having trouble with my wires
0 (0%)
messy wiring harness
0 (0%)
Total Members Voted: 0
Author Topic: starter motor wiring question  (Read 498 times)
Offline holajeffe
« on: January 04, 2011, 08:00:53 AM »
the answer to my question is probably super obvious, but I am a total novice, so bear with me.  I was given a 1973 Cb750 with the engine out of the frame and wiring harness removed and I am trying to figure out which wire is the positive wire to the starter motor.
While I am looking at the engine from the back on the left side there are two cables coming out of the engine-there is a group of wires (green, white, Yellow, Yellow, Yellow) that I am fairly certain is coming from the alternator, then there are two left over wires (green/red and blue/red) in that same group.  There is also a big thick wire coming from the starter that the person before me labeled "to negative battery terminal".
the wires coming from the starter solenoid is yellow/red and black but I can't trace it any further because the whole harness is totally a mess.
was the person that labeled that big thick wire wrong?  If not, where is the wire that connects to the starter is it one of the other two left over wires?
can anyone clear this up for me?
thanks.
Jeff
Offline Spanner 1
Re: starter motor wiring question
« Reply #1 on: January 04, 2011, 09:32:25 AM »
The big fat black wire from the starter motor is the positive wire ( + ). It goes up to one post on the solenoid. The other solenoid post gets the short wire from the battery ( + ) terminal. :)
Offline holajeffe
« Reply #2 on: January 04, 2011, 10:02:05 AM »
excellant, thanks!  I just tested it and everything is hunky dory...the big, black wire being labeled "negative" was just baffling me.
