Author Topic: 750 starter motor wiring question  (Read 872 times)
Offline holajeffe
« on: January 04, 2011, 09:14:42 AM »
I am sure the answer to my question is super obvious, but as I am a total novice please bear with me...I was given a 1973 Cb750 with the engine out of the frame and wiring harness removed and I am trying to figure out which wire is the positive wire to the starter motor.
While I am looking at the engine from the back on the left side there are two cables coming out of the engine-there is a group of wires (green, white, Yellow, Yellow, Yellow) that I am fairly certain is coming from the alternator, then there are two left over wires (green/red and blue/red) in that same group.  There is also a big thick wire coming from the starter that the person before me labeled "to negative battery terminal".
the wires coming from the starter solenoid is yellow/red and black but I can't trace it any further because the whole harness is totally a mess.
was the person that labeled that big thick wire wrong?  If not, where is the wire that connects to the starter is it one of the other two left over wires?
can anyone clear this up for me?
thanks.
Jeff
Offline Rocker
  • The one, the only!
Re: 750 starter motor wiring question
« Reply #1 on: January 04, 2011, 09:35:45 AM »
Go here:
http://www.sohc4.net/index.php/cb750
and here:
http://forums.sohc4.net/index.php?topic=426.0
Both have links to docs and wiring diagrams that will help.
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline Patrick
« Reply #2 on: January 04, 2011, 10:18:46 AM »
But, for starters, the cable from the starter does NOT go to the battery, either terminal. It goes to the starter solenoid.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline holajeffe
« Reply #3 on: January 04, 2011, 10:24:28 AM »
thanks guys!  I got it sorted out (I accidentally posted this question in two places on the forum and someone else pointed out that the big black cable was labeled incorrectly)...the person who had the bike before me must have thought the left terminal of the starter solenoid was negative so when he took it apart he labeled it as such.
that was really throwing me, but now it's all clear!
J
