Author Topic: rear cush drive  (Read 672 times)
rear cush drive
« on: January 04, 2011, 11:33:18 PM »
i see the rear rubber cush drive is discontinued for the 500 on the david silvers site,anyone know where they might be able to be found anywhere else?its a two piece rubber affair per drive lug,ill try some 550 ones i have here,they are joined by a strip.
Offline bird
Re: rear cush drive
« Reply #1 on: January 04, 2011, 11:39:59 PM »
Could be wrong, but they look similar to those on the CB750. Perhaps others know if the two bikes shared similar hubs.
Offline petercb750
Re: rear cush drive
« Reply #2 on: January 05, 2011, 12:37:49 AM »
I haven't had my rear wheel out for a while, but from memory they are joined too? I have been wrong once before.......... ::) :D
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Re: rear cush drive
« Reply #3 on: January 05, 2011, 01:13:48 AM »
yeah this pair look identical apart from the umbilical cord bit and the lack of the spear barb on the locating spikes.
Offline petercb750
Re: rear cush drive
« Reply #4 on: January 05, 2011, 01:35:11 AM »
Is it all possible that the joining bit could be cut off without compromising the cush effect?
Re: rear cush drive
« Reply #5 on: January 05, 2011, 01:38:53 AM »
the joined pair came from a 550 hub,must be some kind of improvment,itll have less part numbers aswell?ill try it out and see,im getting a new rear tyre so i did the shoes aswell,there seemed to be a bit of wobble in the carrier even though the ring nut was tight,backlash seemed non existant.
