Author Topic: starter motor c b 750 k4 continually in action  (Read 898 times)
Offline neil10
« on: January 05, 2011, 06:32:46 PM »
wont stop winding
Offline CycleRanger
  • No comment about being an
Re: starter motor c b 750 k4 continually in action
« Reply #1 on: January 05, 2011, 06:47:55 PM »
Let
go
of
the
button!
Offline neil10
« Reply #2 on: January 05, 2011, 07:05:18 PM »
THks for nothing
Offline CycleRanger
« Reply #3 on: January 05, 2011, 08:03:01 PM »
Well ok, in an attempt to be less funny and more helpful I would check the starter solenoid first, it may be stuck.
If the solenoid checks out ok you might then check the starter button, the internals may be worn or loose and making constant contact.
If the problem persists you'll have to break out the wiring diagram and trace the circuit looking for worn, frayed, or shorted wires.
« Last Edit: January 05, 2011, 10:13:40 PM by CycleRanger »
« Reply #4 on: January 05, 2011, 09:47:16 PM »
Disconnect either of the small solenoid wires; if the starter stops, the problem is in the start button or associated wiring. If it continues to run, the solenoid is at fault.
Offline Spanner 1
« Reply #5 on: January 05, 2011, 10:22:29 PM »
Scottly +1.... does the st.mtr. spin as soon as the ign. is turned on ?, or won't stop when you let go of the start button ?
