Author Topic: Fiberglass or plastic tanks and todays gas  (Read 6517 times)
Offline Scott S
« on: January 06, 2011, 06:12:52 AM »
 This isn't specifically about the SOHC4's, but I thought the answer might help someone out with THEIR SOHC4, so....
I've been desperately searching for the right tank for my KZ250 cafe' project. I've found a few plastic or (older) fiberglass tanks that may fit the bill, but I'm worried about the effects of todays gas.
Is there a safe way to run a 'glass or plastic tank with ethanol laced fuel?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
Re: Fiberglass or plastic tanks and todays gas
« Reply #1 on: January 06, 2011, 06:24:11 AM »
You will probably have to coat it. There are quite a few threads here on sealing a tank.  Friend had a Tracy tank/fairing that had to be sealed...Larry
Offline Scott S
« Reply #2 on: January 06, 2011, 06:29:09 AM »
 But I know a guy with a new 'glass tank that was coated and it still ate through it.
 Does it matter if the tank is older? Is it just the gas or the construction of the tank? I see lots of dirt bike tanks that are plastic. Do they suffer the same fate?
'71 CB500 K0
'81 Yamaha XS650
Offline Outboardbill
« Reply #3 on: January 06, 2011, 06:48:18 AM »
I run a boat repair facility.  For many years Boston Whalers used a fiberglass tank.  They don't any longer.  I have seen those tanks begin to dissolve in the presence of ethanol and send fibers and resin into the outboard fuel system.  It then blocks carb passages and eventually destroys the engine.  The dissolved resin will get past a fuel filter.  I have been told that newer resin systems can tolerate ethanol but I don't take the chance.
Offline fmctm1sw
« Reply #4 on: January 06, 2011, 07:37:27 AM »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
nomad
« Reply #5 on: January 06, 2011, 07:51:19 AM »
Local stations that sell ethanol free gas...
http://pure-gas.org/index.jsp
Offline Scott S
« Reply #6 on: January 06, 2011, 07:57:20 AM »
 And not a single one in my hometown...   >:(
'71 CB500 K0
'81 Yamaha XS650
nomad
« Reply #7 on: January 06, 2011, 08:01:56 AM »
Mine neither.  But I'm going to take a few gas cans (or buy one big one for the garage) and find the closest one.  The closest one to us is roughly 40 minutes away.  Maybe I should have written "local (if you're lucky) stations" in my first post.   :-[
Offline domer
« Reply #8 on: January 06, 2011, 08:09:08 AM »
#$%*... my state isnt even on there... #$%*ing cali hippies >:(
Offline Trav-i
  • Has finally become an
« Reply #9 on: January 06, 2011, 08:24:01 AM »
None in my hometown either.  However there is one place about 20 or 30 minutes north of me.  Wonder if it's worth the trip?
Forum member #9962
1992 GL1500 Interstate
Offline Shoeboxjoe
  • Large Breasts
« Reply #10 on: January 06, 2011, 08:29:12 AM »
I run a glass tank and the coating from the builder wasn't sufficient, gas ate right through it at one of the corners (or it was a poorly sealed tank). I cleaned it out and recoated it with Caswell's Epoxy Gas Tank Sealer (http://www.caswellplating.com/aids/epoxygas.htm) and its rock solid, I couldn't be happier. They claim on their site it withstands modern ethanol based fuels and I'd have no reason to doubt it, they're stuff seems pretty quality.
I used twice the recommended amount (the whole pint) in my application though to make sure it was a thick coating since i knew i already had a leak.
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: January 06, 2011, 08:40:53 AM »
It's probably just the fiberglass tanks you have to worry about.  If dirt bike tanks are made from the same kind of plastic that your typical gas can is made out of then they shouldn't have any issues.
nomad
« Reply #12 on: January 06, 2011, 08:50:53 AM »
I'm about to redo the fouled up kreem job in my tank with the POR15 cycle fuel tank repair kit.  After reading this thread, I started wondering about their sealant's ability to handle ethanol gas.  So, I called them.  The POR15 rep said without hesitation that ethanol will not affect their coating... whew - good to know!  8)
Now I'm wondering if there are special fuel lines I should look into.  Doesn't ethanol eat rubber over time?
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #13 on: January 06, 2011, 09:58:46 AM »
How did you clean it out?  My Dunstall tank already had a liner from the po, but I also have a quart of Caswell in case it ever starts to leak.
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline Shoeboxjoe
  • Large Breasts
« Reply #14 on: January 06, 2011, 10:14:13 AM »
I followed Caswell's instructions on their site for cleaning and preparing the tank which involved acetone and paint stripper with methylene chloride... needless to say my shiney new paint job on the tank needed some "touch ups" after this process.  >:(
Before I painted the tank, which i bought new, i asked the vendor/builder if he recommended I seal the tank again just to be safe. He replied "My tanks NEVER leak" and seemed insulted I would even suggest it needed additional work.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #15 on: January 06, 2011, 04:13:15 PM »
I just saw this site advertised in Classic Bike:
http://tankcareproducts.co.uk/
Maybe something there is helpful.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #16 on: January 06, 2011, 04:40:54 PM »
I did my Tracy with Por15 2-3 years ago. I spoke with someone in the R&D office and was told it is fine. My tank looks great still ;)
Offline Gaither
  • '77 CB550F
« Reply #17 on: January 06, 2011, 06:20:10 PM »
Fmct
Thanks for the Evenrude link. Man, they "tell it like it is"!
IMHO This info should get a full page in every news paper in the U.S.
Even the Gov is (and has been) lying about ethanol. And, ALL taxpayers subsidize every gallon produced - to the detriment of our own vehicles (and a 10% reduction in fuel mileage).
What a crapy mess!
Gaither ('77 CB550F)
Offline Spiider
  • '73 CB750k
« Reply #18 on: January 07, 2011, 02:53:19 PM »
That and you also have to consider the massive negative impact ethanol has had on third world food prices.
When you make a commodity into fuel source much more valuable than it price as a food source...people starve.
We don't feel it here as the average north american spends only 3% of their disposable income on food, but in third world countries they rely on cheap staples like corn, soybeans, rice etc. as their main food. They also spend more than 50% of their income on food generally.
World food prices are at near all time high, almost as high as the food crisis of 2008.
The use of ethanol isn't just a major inconvenience to guys like us, it is literally live or die for many starving people in the world who now can't afford to eat. The US is the worlds largest producer of corn...
Oops my data is a few days late...
http://www.cbc.ca/world/story/2011/01/05/world-food-prices-record.html
We have hit a new record....and food riots have begun again.
« Last Edit: January 07, 2011, 02:55:33 PM by Spiider »
Offline Gaither
  • '77 CB550F
« Reply #19 on: January 07, 2011, 05:54:00 PM »
Spiider
Right on! It even jacked up food prices considerably in the U.S.
It is ALL just a crying SHAM!    (And, yes, I do know how to spell "shame"!)
Offline Spanner 1
« Reply #20 on: January 07, 2011, 06:37:34 PM »
Gaither +1..... it should be a moral issue to avoid buying ethanol gas, but very few of us have that option or are aware of the facts. I'm super lucky that my nearest gas station is ethanol free  ;D
On a side note, the era of 'big corn' needs to be over, 'high fructose corn syrup 'is in everything, take a look at every food item you pick-up at the grocery store. Way part of the diabetes epidemic IMO.
Offline Gaither
  • '77 CB550F
« Reply #21 on: January 07, 2011, 07:10:53 PM »
Spanner
+100!! You are absolutely correct! It needs to end - SOON!
Yeah, ethanol free is available in 1 station within 8 miles of me (out of 10 or 12). This guy has both with & without. Previously, he sold both at the same price. Now, he gets 6 cents more for ethanol free. Disagreeable but considering a 10% mileage diff, it is still worth it (not considering all the many other reasons to not use ethanol laced fuel).
I always try to swing by there after a ride to fill the 550 - even when it isn't convenient.
Thanks
Offline KeithB
« Reply #22 on: January 09, 2011, 03:44:29 AM »
I can't comment on the effect of the gas but before you install, it might be worth checking if it's legal to use  for street riding.
It's not legal here in Ontario and the insurance companies might have something to say if you get into an accident with a non approved gas tank.
just my $.02 worth...
Nanahan Man
