Author Topic: CB550 Cylinder Head Compatibility  (Read 3617 times)
Offline Nabors12
« on: January 06, 2011, 09:12:14 AM »
Just started a restoration on a 1978 CB550 and immediately ran into my first issue. While removing the spark plugs, one of them broke off in the head. I used an easy-out on it and needless to say, it broke off inside the plug. I'm thinking I will have to find a new head and was wondering if the cylinder heads from other years were compatible with my 1978 550K, for instance a cylinder head off a 1974 CB550 KO?
Thanks
« Last Edit: January 06, 2011, 09:35:15 AM by Nabors12 »
Offline turboguzzi
Re: CB550 Cylinder Head Compatibility
« Reply #1 on: January 06, 2011, 10:11:19 AM »
a good machine shop should be able to remove it
in any case, you could use a 500's head too as well as other 550's,  no significant differences.
Offline Kong
« Reply #2 on: January 06, 2011, 10:31:17 AM »
I can not possibly picture in my mind how a person manages to "break off" a spark plug, nor can I envision even finding a way to get an easy-out into what might be left of the plug although everyone who's ever owned a set of easy-outs knows how easy they are to break.
Is there any chance at all you have a picture of this mess?  I'd really like to see just what it is you have to work with.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Nabors12
« Reply #3 on: January 06, 2011, 02:35:05 PM »
Despite how I feel your response may have been a little condescending, since breaking ancient spark plugs in half in engines found in barns is not rare, here are some pictures.
Offline Kong
« Reply #4 on: January 06, 2011, 02:52:41 PM »
Sorry to sound condescending, that certainly was not my intention.  I really was wanting to know just what had happened.  To be honest with you, I've broken my share of porcelain tops, but I've never seen one rung off at the base like that.  You know, if the easy-out - which must be a pretty hefty one - is still stuck in there you may be able to concoct a way to not try to back it out, but maybe be able to continue to screw it right on though into the combustion chamber and out; that is with the head off of course.  With the tap broken off I don't see how you can avoid taking the head off.  Once that's the case I'd take it to the local machine shop myself and act real nice to the proprietor.
That is one hell of a thing though, first time I've ever seen it.  I wish you luck.
« Last Edit: January 06, 2011, 02:56:21 PM by Kong »
1978 Honda CB550K
1977 Honda CB550K
« Reply #5 on: January 06, 2011, 02:55:14 PM »
Perhaps this is a good lesson on why the Stock Honda toolkit Spark plug tool works so well.
Notice the bell design which easily clears the obstructions in the access tunnel.
Yes, you can find thin wall sockets that will work.  But, none do a better job on the spark plugs for inner cylinder 2/3 access, without introducing side loads on the spark plug base.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: January 06, 2011, 03:46:43 PM »
If your taking the head off anyway I say go the machine shop route. And while you're in there have them clean it up a bit and replace valve guide seals have your valves lapped and whatever other work needs to be done. It doesn't cost that much and it will seem like a new motor again.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nabors12
« Reply #7 on: January 06, 2011, 08:43:10 PM »
Thanks for the replies. I have begun breaking down the head and should have it all taken apart tonight. Whoever's idea it was to put screws on a head assembly should be shot, luckily I bought an impact driver and mallet that made them come out easily. Definitely going the machine shop route if I can get it done for a reasonable price. Really don't want to go to crazy since I found an old head online for 50 bucks, although since you pointed out the possible issues with the earlier model heads I may get it machined regardless.
« Reply #8 on: January 06, 2011, 09:12:35 PM »
I cannot imagine working on a CB w/o an impact driver.
« Reply #9 on: January 06, 2011, 09:34:13 PM »
FYI, cylinder head cover and cylinder head are two different parts.  The 78 should already have the upgraded cylinder head cover (cam cover).
Offline Nabors12
« Reply #10 on: January 07, 2011, 02:44:46 AM »
Update on my progress with pictures, cylinder head has been pulled. Thank goodness for this forum when it came to separating the head, those two pry spaces that Honda added were genius.
Any comments on the state of my cylinders is welcome.  :)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: January 07, 2011, 10:20:48 AM »
Can't see super close but it looks like a good cleaning, valve lapping, and replace all rubber and gaskets and you're good to go. There are rubber guide seals just below the valve springs that get old and brittle. How are the valve guides? Sloppy? tight?
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
