Author Topic: My 'home made' CB750 K0/Sandcast alternator Sub-Harness  (Read 1337 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: January 07, 2011, 02:19:17 PM »
My 'home made' Cb750 K0/Sandacst alternator Sub-Harness
« on: Today at 10:17:18 PM »
Quote  Modify  Remove
Here is a link to a pic of my K0 'home made Alternator sub-harness, Can anyone tell me if the sleeving on the neutral switch looks correct for Sandcast/early K0. It's different to the Yamiya one but I reckon the Yamiya one is not faithful to the original. ChrisR kindly sent me a picture of a used early one. This has taken me almost a month of research to find the correct materials. I could not use the multi-way connector supplied By Vintage Honda Connections because it was different to the original, so I ultrasonically cleaned an old one which has not 'scrubbed up' too badly. His crimps supplied with the multi way were correct though and fitted perfectly into a genuine shell. the outer sheathing is rubber and the braided sleeving (two sizes) is silicone impregnated woven glass. The sleeving ends are covered with clear 3-1 ratio heatshrink tubing (tape on the original I think) and the neutral switch eyelet is covered in a Raychem heat shrinkable, adhesive lined  coupling sleeve.
http://i697.photobucket.com/albums/vv340/AshimotoK0/AlternatorsubloomK0.jpg
http://www.yamiya750e.com/index.php?main_page=product_info&cPath=21_58&products_id=73
Watch this space for a correct 'home made' replica braided battery earth lead. The Yamiya one is definitely incorrect and a very poor copy, in my view. The correct cable has soldered lugs and a braided outer - multi strand inner
http://www.yamiya750e.com/index.php?main_page=popup_image&pID=485
This one looks correct though:
http://cgi.ebay.co.uk/Honda-CB-750-Four-Sandcast-Massekabel-Original-/220632204569?pt=Motorrad_Kraftradteile&hash=item335eb44519#ht_500wt_725
Cheers for now  AshD
« Last Edit: January 07, 2011, 02:31:07 PM by AshimotoK0 »
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline Alan F.
Re: My 'home made' CB750 K0/Sandcast alternator Sub-Harness
« Reply #1 on: January 07, 2011, 02:25:07 PM »
That looks great, nice work!
