Author Topic: 400 carbs?  (Read 926 times)
400 carbs?
« on: January 10, 2011, 10:35:30 PM »
can anyone please tell me what size carbs were fitted to the 400s?a guy wants to know if he can fit a set from a 500 to his 400,i told him the spacings would be wrong etc,or can the 500 carbs fit on 400 runners?
Offline Kevin400F
Re: 400 carbs?
« Reply #1 on: January 11, 2011, 03:28:48 AM »
CB400F carbs are 20mm Keihin (same size as the CB350F).  The carb throat center-to-center spacing is narrower than the CB500, so it would be difficult to adapt the CB500 carbs (which I believe are 22mm).
Offline MoMo
  • Ride like you're invisible
Re: 400 carbs?
« Reply #2 on: January 11, 2011, 03:34:18 AM »
Tried to do it once, would have been too much work to make it worthwhile...Larry
Re: 400 carbs?
« Reply #3 on: January 11, 2011, 12:44:36 PM »
thanks fellas, i told the guy that would be the case,just checking if someone else had a trick,he has a bike with no carbs and cant find any for sale,i told him to look for 350 ones aswell.
