Author Topic: Admitting you have a problem is the first step. CB550 build  (Read 15027 times)
Offline Willy D
Re: Admitting you have a problem is the first step.
« Reply #25 on: April 10, 2011, 06:00:01 AM »
Here's the left side rearset finished with linkage installed and bracket polished. I took the original shift lever, cut it off and rotated it. Had to bend it a little to work.
Offline Willy D
« Reply #26 on: April 11, 2011, 07:45:26 PM »
I got the front and rear fenders painted this weekend. Mounted them up tonight.
Offline MasterChief750
  • Detonation
« Reply #27 on: April 12, 2011, 03:26:36 AM »
is that a gto peeking out or am i blind
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Willy D
« Reply #28 on: April 12, 2011, 05:46:13 AM »
The red one is a 64 the turquoise is a 68. Old Pontiacs are something else that can be addictive.
« Last Edit: April 12, 2011, 05:58:01 AM by Willy D »
Offline Willy D
Re: Admitting you have a problem is the first step. CB550 build
« Reply #29 on: May 18, 2011, 07:19:36 PM »
Time for a couple updates as i have been making progress on the bike lately. I heated and bent my kick starter pedal with a torch so that it would clear the rearset brake lever. It actually was pretty easy to do, they were forged originally and seems to be made of good quality steel.
Offline Willy D
« Reply #30 on: May 18, 2011, 07:28:16 PM »
I got a decent deal on a cb500t tank on ebay. i have always liked the shape of this tank better than the stock 550 tank. It took some minor modification to get it to fit right, but it turned out good. You could use it without moving the petcock location, but moving it worked out better for me. I took a small hole saw and cut out the original threaded pipe, drilled a new hole and welded it in. There was a small plate spot welded to the inside of the tank in the original location which left a lip so i took and welded a flat round slug in that location.
Offline Willy D
« Reply #31 on: May 18, 2011, 07:37:14 PM »
I wanted the tank to sit further forward than the stock mounts would allow so i cut off the radius portion and extended the mounts with some 1/2" strips welded to the back portion of the original mounts. In the back i added a flat plate to the stock mount and used some rubber bushings off a shock absorber to mount it to the frame.
Offline fastbroshi
  • Puppet
« Reply #32 on: May 19, 2011, 03:36:05 AM »
Cool mods on the tank.  I see you've got the dual flipped disc figured out.
Just call me Timmaaaaay!!!
Offline Willy D
« Reply #33 on: May 19, 2011, 05:33:21 AM »
The disc mount was all stock parts, but I did have to grind one of the mounting bosses down so that the caliper would line up parallel to the rotor and tap the hole.
Offline Willy D
« Reply #34 on: May 23, 2011, 05:53:20 AM »
Painted my tank and side covers this weekend. First i painted them charcoal grey like the pictures i posted earlier-I hated it! went back and painted them again with black.
Offline fastbroshi
  • Puppet
« Reply #35 on: May 24, 2011, 12:39:37 AM »
Good call, black is classic.
Offline Willy D
« Reply #36 on: June 10, 2011, 05:27:53 AM »
I finally came up with the finishing details for my tank. Less is more right?
Offline Syscrush
  • Sold. :(
« Reply #37 on: June 10, 2011, 07:37:34 AM »
Very nice build.
Are you worried about the bent kicker being able to handle the necessary forces?  I'm thinking both of the effect of the heat & bend and the new geometry meaning that there's a pretty large torsional force now.
Offline Willy D
« Reply #38 on: June 10, 2011, 08:27:28 AM »
Very nice build.
No not really. When we heated it, it seemed to be forged out of pretty good steel. I have a little experience heating and bending dropped axles ect. I figured worst case if it broke all at once the worst thing that would happen is my foot would hit the ground. I was also worried about shortening the lever arm and making it harder to turn the motor over but it still works fine.
Offline canibeyou2
  • oh yes i did
« Reply #39 on: June 10, 2011, 09:19:57 AM »
i like what you're doing.  i always appreciate seeing those custom touches.  very nice looking bike.  say hi to the girls in goodletsville for me.
past ownership
73 yamaha xs650
74 moto guzzi interceptor 850
76 harley davidson flh
93 suzuki gsxr 600
91 yamaha fzr 600
1989 kawasaki ninja 250
1987 kawasaki ninja 500
2005 honda vtx 1300
today's garage
2005 yamaha r6
1972 honda cb750
Offline Syscrush
  • Sold. :(
« Reply #40 on: June 10, 2011, 09:32:04 AM »
Good to know, thanks.
I want to put rearsets on mine and go kick-only, so I'm interested in other people's solutions.
Offline Willy D
Finally finished! .......well almost
« Reply #41 on: June 11, 2011, 07:54:27 PM »
Final assembly today test rode around the yard. I have to work on the front brakes a little more before I will feel comfortable getting on the road. I only took one pic today.
Offline ScottCB550
« Reply #42 on: June 13, 2011, 04:57:11 PM »
i like that seat...where did you get it from?
Offline Willy D
« Reply #43 on: June 13, 2011, 06:51:27 PM »
I got the seat off Ebay. check out this thread:  http://forums.sohc4.net/index.php?topic=83188.msg937557#msg937557
let me know if you have any more questions.
Offline Willy D
« Reply #44 on: June 25, 2011, 08:32:57 AM »
I took a few more pictures of the finished for now project. I had to sort out some tire mounting issues after a few test rides, when they mounted my new tires, they didn't clean all the rust off the bead seating area so the tire could not move all the way out and seat evenly. I bought a set of tire tools took it off myself and cleaned it up.
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #45 on: June 25, 2011, 10:06:49 AM »
Very nice story and very nice build.....looks great!
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
Offline Willy D
« Reply #46 on: June 25, 2011, 12:11:19 PM »
Thanks to everybody and all the info on this site. I couldn't have done it with out them.
Offline Willy D
« Reply #47 on: May 27, 2012, 05:59:00 AM »
I thought I would post a few pictures of some work I did over the winter. Because of paint problems I had to repaint my tank and side covers. Got tired of the Honda decals so I went with a new scheme that is more Honda looking to me-sort of Black Bomberish. I also added new exhaust-a 4 into 2 set of NOS I got off ebay, changed the clubmans out for Norman Hyde M bars, added a new larger taillight that I think fits the style better.
Offline Willy D
« Reply #48 on: May 27, 2012, 06:02:24 AM »
couple more:
Offline fastbroshi
  • Puppet
« Reply #49 on: May 27, 2012, 09:41:55 AM »
That second rendition looks great, good job!
