Author Topic: rebuild motor question  (Read 673 times)
Offline wicat
« on: January 12, 2011, 08:12:24 AM »
Im looking to overhaul my 1973 cb750 motor and just get it up and running without going crazy but i want the motor to be reliable so what should i replace no mater what and what should be looked at to see if it needs to be replaced?
Offline Old Scrambler
Re: rebuild motor question
« Reply #1 on: January 12, 2011, 08:28:05 AM »
Complete Gasket Kit and Oil Seal Kit and pay attention to the early (K2) head versus later year heads with the different dowels and seals.  Be sure to get the replacement pads under the cam tower and the valve seals. I recommend the Cycle-X gasket and seal kits because they are complete.
Cam chain side-play?
New Rings?
Valve seats?
Tranny drum & shift forks?
Clutch plates?  Primary Chain for Tension and wear on the cases?
Pri
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
