Author Topic: Would this work in a 76 550?  (Read 1194 times)
Offline Rocker
  • The one, the only!
« on: January 13, 2011, 05:36:58 PM »
Dime City has a good deal in an awesome speedo/tach/dummy light all in one unit:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-streetfighter-acewell-2853-digital-motorcycle-speedo-speedometer-tach-tachometer-19-2853-bk.html
Turn and bright light indicator should not be hard to hook up but I am wondering about the speedo/tach. Also there is a fuel light indicator on the unit. Any one installed an aftermarket sensor in their tank?
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline sniper
Re: Would this work in a 76 550?
« Reply #1 on: January 13, 2011, 06:01:50 PM »
As far as the sensor in the tank no. But my friend installed the same one you are looking at he loves it. It has a blue light so he can see how fast he's going and what rpm he is at. He had a little trouble installing at first but figued it out. I guess the only problem is calibrating the speedo to the exact speed he's going at..
Hope this helps in out a bit..
Kind regards Sniper
Offline Rocker
« Reply #2 on: January 14, 2011, 09:06:36 AM »
Would be a tricky setup in a 550 running a 650 cam. Would need to calibrate the speedo for the 550 and the tach for the 650. Wonder if that's even possible.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #3 on: January 14, 2011, 10:42:16 AM »
Looks like the speedo is a magnetic counter for attaching to either wheel - you probably measure the wheel outer and tell the
processor - like on bycycle systems. The revs are normally taken from the power feed to the coils, so it just counts sparks, hard
to go wrong and will work on any bike.
In the UK anything over 40 years old only needs insurance and Fuel.
