Author Topic: '77 cb750f2 cafe project  (Read 20950 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: '77 cb750f2 cafe project
« Reply #75 on: September 08, 2015, 06:07:20 PM »
Also, are my turn signals supposed to be running turn signals as well? Currently they are not right now.
Stock, all of the signal lights are amber. Rear running lights are almost universally required to be red, so the rear lights are a single filament signal light only, while the front facing signals are typically dual filament and serve as both running lights and signal lights.
May not get to the headlight bucket tonight, just got home after hanging with calj737 and CBertels looking over Chris's bike and bouncing ideas around about the amount of work he's got to do.
Not always the case. Many running lights on the rear of motorcycles include the indicators using a dual filament, so that they show a solid amber with a brighter turn signal.
The only way to tell is to remove the bulb and determine whether the socket is designed for a single filament or dual filament bulb.
We're talking about a 77 CB750F which stock had dual filament signal lights up front and single filament signal lights in the rear (refer to wiring diagram in previous post). Not to say that someone could not have changed the rears to dual filament, because they could have very easily. In fact, I have sourced red lenses and am considering converting the rear signals on my K8 to red lens dual filament signals.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline kenneyginter
  • im trying
« Reply #76 on: September 08, 2015, 09:02:16 PM »
@madmtnmotors that picture inside your headlight would really help..I am still not getting it.
77' cb750f2 cafe project
build thread http://forums.sohc4.net/index.php?topic=82251.0
« Reply #77 on: September 09, 2015, 02:20:20 PM »
You should find two brown wires with a blue stripe in the headlight bucket. One should have a male bullet connector which comes from the turn signal switch harness from the handlebar. This would connect to the turn signal buzzer. I jettisoned my turn signal buzzer a long time ago so this wire is not connected to anything in my headlight bucket.
The other brown with blue stripe should terminate to a female bullet with a yellow insulator (I knew there was some yellow in there somewhere). The stock harness would have a brown with blue stripe jumper wire with a yellow band on one end and a black band on the other end. This adapts the brown/blue female to a black female for power to the taillight.
EZPZ  8)
« Last Edit: September 10, 2015, 11:55:54 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
  • im trying
« Reply #78 on: September 10, 2015, 09:21:39 AM »
This is appearing as a broken link! Bummer, can you try and repost it?
« Reply #79 on: September 10, 2015, 09:47:36 AM »
Should be fixed.
TAMTF...
Wilbur
Projects:
  • im trying
« Reply #80 on: September 10, 2015, 10:50:46 AM »
still no luck?
« Reply #81 on: September 10, 2015, 11:26:27 AM »
How about now?
« Last Edit: September 10, 2015, 11:56:19 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #82 on: September 14, 2015, 04:59:34 AM »
How about now?
TAMTF...
Wilbur
Projects:
  • im trying
« Reply #83 on: December 10, 2015, 11:29:04 AM »
hey guys, if anyone is looking for a great charity to donation to before the end of the year, I am running the 2016 Boston Marathon and I am pumped. See link below;
https://www.crowdrise.com/AmericanRedCrossBoston2016/fundraiser/scottjohnsonw
If anyone decides to donation please PM me your address, I will be sending out thank yous
