Author Topic: ??easy muffler fix??  (Read 3594 times)
Offline cafenut
  • it dont hurt till the bone shows
« on: January 14, 2011, 01:27:07 AM »
does anyone have a good solution to a couple pinky sized holes or smaller in the bottom of muffler? thought maybe some type of putty or something? 78 k
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
76 750 k chop project
Offline Gordon
  • 750K1, 550K2
Re: ??easy muffler fix??
« Reply #1 on: January 14, 2011, 07:39:49 AM »
Get a tube of Muffler Mender at the parts store.  It's a thick paste that cures when it gets heated up by the exhaust.  It's been plugging a hole in one of my stock 550 pipes for a few years.  Obviously any patch job like this is only temporary, though, because the rust is happening from the inside out, and the total damage is much larger than the size of the hole.
Bud Man
« Reply #2 on: January 14, 2011, 07:43:43 AM »
Good ol' JB Weld has worked well for years for me.  But as mentioned earlier, its only a temporary fix.....   >:(
Bud
Offline florence
« Reply #3 on: January 14, 2011, 07:45:43 AM »
If you leave the hole it lets the moisture out!
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: January 14, 2011, 07:59:14 AM »
Even better, if you take all the mufflers off then there's nowhere for moisture to get trapped at all!  Problem solved! ;D
Offline bikerbart
« Reply #5 on: January 14, 2011, 09:13:37 AM »
the muffler mend tape,cut a 1/2 square or circle,stick on.It doesnt look as crappy as a wad of putty,and its metal tape,temp fix but quick and easy.Seems to last a couple of years so far.
Offline gnarlycharlie4u
  • Far from being an
« Reply #6 on: January 14, 2011, 11:55:00 AM »
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: January 14, 2011, 12:14:38 PM »
The mending paste is pushed into the hole and smoothed out to match the contour of the muffler.  You don't just ball it up and stick it on the outside of the hole. ::) ;D
Offline bikerbart
« Reply #8 on: January 14, 2011, 12:52:49 PM »
you dont?it ends up looking like someone stuck a wad of chewing gum on it,(if I do it)I was only adding another suggestion,sheesh. ::) :-*
Offline tango911
« Reply #9 on: January 14, 2011, 01:17:02 PM »
easy muffler fix.   cut them off :P
nice and loud
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: January 14, 2011, 01:24:43 PM »
That's what she said.  :o
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: January 14, 2011, 01:44:50 PM »
I know, but if my suggestion gets trashed in the process I've gotta stand up for it! ;D ;)
Offline bikerbart
« Reply #12 on: January 14, 2011, 04:57:54 PM »
get up stand up,stand up for your fix
Offline BeSeeingYou
« Reply #13 on: January 14, 2011, 05:26:09 PM »
Jah mon. :D
Offline cafenut
« Reply #14 on: January 15, 2011, 04:18:09 AM »
 :D lol. thanks guys. pretty much the suggestions i thought id get. just wasn't sure if some miracle cure came along in the last 4 years since I've had to fix a muffler.
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
